GLM-5.3-Flash (NVFP4+DFlash2) on 2x Spark: does not scale with concurrency - anyone else seeing this?
GLM-5.3-Flash (NVIDIA NVFP4 + DFlash2) on 2× DGX Spark: great single-stream and long-context, but aggregate tokens/s does not scale with concurrency — anyone else seeing this?
Over the weekend I trialed the GLM-5.3-Flash NVIDIA-NVFP4 + DFlash2 recipe
(GitHub - 0rand/glm-5.3-flash-nvidia-nvfp4-dflash-2x-dgx-sparks: GLM-5.3-Flash NVIDIA official NVFP4 + DFlash2 on 2x DGX Spark — TP=2 over RoCE, cudagraphs + async scheduling, verified 700K ctx (hardmode 94/100), one .env · GitHub, pilcothink vllm_spark_glm53:0.28
runtime) on my 2× DGX Spark pair, side by side with the stack I run in production, DeepSeek-V4-Flash
(0731) on aidendle94’s sparkrun-vllm-ds4-gb10:production-3.7 DSpark image
. Both TP=2 over a
200 Gb/s ConnectX-7 RoCE link, both nodes headless. Sharing the numbers because one result surprised me
and I had not seen it mentioned anywhere.
Setup / fairness notes. Same hardware, same day, GPU clocks capped at 2000 MHz on both nodes for both
stacks (thermal mitigation I run permanently — so absolute numbers are ~25–30 % below what an uncapped
Spark does), same benchmark tooling (tool-eval-bench v2.0.7 for quality and spec-bench, llama-benchy for
single-stream, and a small concurrency harness that fires N identical 1K-token requests with 512 output
tokens and reports total tokens / wall time). Everything warmed before measuring.
What GLM does well. Single-stream decode is ~33 t/s and it is flat with depth: 33.0 / 33.1 / 32.0 / 34.0 /
33.6 t/s at 0 / 2K / 8K / 64K / 128K context. Prefill is ~920 t/s past the first chunk (so 128K of context is ~2
minutes to first token). DFlash2 acceptance is excellent on code and structured output (86–92 %, ~4.4
accepted tokens per step) and poor on prose (38–55 %). Tool-calling quality matched DeepSeek exactly on
tool-eval hardmode (89/100 vs 89/100 at 20 parallel scenarios). It did not leak on a prompt-injection
probe that the 0731 DeepSeek release fails. HumanEval was lower (147/164 vs 158/164).
The surprise: aggregate throughput is flat.
concurrency GLM-5.3-Flash + DFlash2 (agg t/s) DeepSeek DSpark (agg t/s, same day)
1 33 31
4 43–46 98
8 43–44 143
16 45 (243 on an earlier uncapped day)
Going from 1 to 16 clients moves GLM’s total from 33 to 45 t/s while per-request speed collapses from 33 to
5 t/s and TTFT at c8 balloons to ~28 s. I first assumed it was the recipe’s scheduler profile
(max-num-seqs 4, max-num-batched-tokens 1024, tuned for one long-context user), so I rebooted with
seqs 16 / batch 4096 and then seqs 16 / batch 2048: same ~45 t/s ceiling. The DeepSeek image on the same
iron batches almost linearly to c8. Whatever the DFlash2 verify/draft step is doing at batch > 1 on GB10,
it behaves like a single ~45-token/s pipe shared by all clients.
I have not yet swept the draft depth (k=5 in the recipe); on the DeepSeek side we found spec=3
beat spec=5 under concurrency for exactly this reason, so that is my next experiment. If anyone has
run this stack with several simultaneous clients, or has DFlash2 batching numbers on Spark, I would
really like to compare notes — is this expected for DFlash, or a config/backend issue on my side?
Other gotchas from the weekend, in case they save someone time
  1. The Docker Hub 0.28 tag was re-pushed on 09-12; in that build --per-request-spec-decode-metrics takes a
    value (none|summary|detailed). The recipe passes it bare → vllm serve: error: expected one argument.
  2. The new hf CLI (1.x) stores weights in a content-addressed hub/blobs/<2hex>/<sha> tree; the recipe’s
    download.sh rsyncs only the per-model directory to the worker, which is just symlinks. The worker’s
    “weights=yes” check passes on config.json alone. Sync hub/blobs/ too.
  3. gpu-memory-utilization is a fatal pre-load check in this image and is a fraction of whole-system RAM.
    0.88 missed on my head node by 0.5 GiB; 0.86 works. Do not port GMU values between images.
  4. The head node has ~5 GiB less headroom than the worker (API server + engine core + whatever else you
    host there). With the recipe’s 9 GiB KV pin, DGX OS’s earlyoom (2 % threshold) killed the head’s vLLM
    worker at KV allocation and again under load. A 6 GiB pin was the fix. Check journalctl -u earlyoom
    before blaming NCCL when a worker “died unexpectedly (exit code: None)”.
  5. The display-reserve KV trick (coolbho3k’s allocator, shipped in the recipe as start-display-kv.sh)
    works on driver 580.159: +1.75 GiB KV per rank, +29 % pool at my pin size, no measurable decode tax,
    runtime-only and reversible. It needs both nodes headless and, on my Sparks, the GPU is /dev/dri/card0
    rather than the card1 the scripts assume.
Verdict for my use case (a shared endpoint for several coding agents): DeepSeek/DSpark stays. For a
single long-context user GLM-5.3-Flash on this recipe is a genuinely strong stack. Thanks to 0rand,
pilcothink, coolbho3k and aidendle for the work — happy to share the full logs and configs.
FYI: I’m running C4 on the Intel quant with MTP=3 right now and seeing 58 → 73.
Thanks, that’s a really useful data point. To make sure I read it right: is that 58 t/s single-stream going to 73 t/s aggregate with 4 clients? If so it’s the same shape I’m seeing (33 → 43 on the NVFP4 + DFlash2 k=5 stack, clocks capped at 2 GHz), just from a higher floor — DeepSeek/DSpark on the same pair goes 31 → 98 at c4.
Your higher single-stream makes sense to me: native MTP at k=3 is a cheaper step than a DFlash2 draft at k=5, and on DeepSeek I found k=3 beats k=5 under concurrency for exactly that reason.
I’ll try the Intel W4A16 AutoRound quant with MTP=3 next and report back. BTW, are you running that TP=2 across two Sparks or on one, and on which image?
Look at my small review GLM-5.3-Flash: 320B total parameters / 18B active - #573 by ajvazan
We have new champion of the GLM’s backend.
Sorry for not being clearer. No, single stream C1 is generally 28 → 35 for prose. I was just reporting the ranges from the logs because I don’t spend time running benches. Dudes like @ajvazan do that and then I pick up on what they learn after the fact. My point of dropping in was to tell you that your ceiling of mid 40s is likely due to DFlash2.
A data point from a different setup that might help isolate this. Same model family (GLM-5.3-Flash, 4-bit), but TP=4 across four GB10s on a 100 Gb switch, using the model’s native MTP drafter (k=5) instead of DFlash2. There, aggregate throughput did scale with concurrency:
clients aggregate tok/s
1 50.1
8 134.5
32 280.9
64 413.6
(Real coding prompts, 1,024 max output tokens, counting delivered tokens from the API usage field.)
Caveats, so nobody over-reads it: four nodes instead of two, and our drafter ran eager (enforce_eager on the drafter only; the target kept its CUDA graphs) after a graph-capture crash. So it’s not a clean A/B. But it does suggest the flat curve isn’t inherent to GLM-5.3-Flash on GB10, or to speculative decoding in general. It points at the DFlash2 draft step under batching, which matches what jrsphd saw.
If you get the chance, the same 2× stack with speculative decoding off at c=8 and c=16 would show directly how much the drafter costs you once the batch fills up.
