GLM-5.3 Flash on 2× DGX Spark: 4.7M-token KV cache with fast EXL3 serving
I’m releasing another reproducible two-node serving recipe for GLM-5.3 Flash on a pair of NVIDIA DGX Sparks.
There’s more KV capacity than other recipes because of various tricks: approximately 4.6–4.7 million logical KV-cache tokens at a 1M context limit with two 128 GB DGX Sparks. That is roughly 4.5 full 1M-token contexts!
Repository:
The canonical configuration is:
  • EXL3/TR3 4-bpw routed-expert weights
  • FP8 E4M3 KV cache
  • Compact 528-byte NoPE MLA cache layout
  • FP8 sparse indexer cache
  • DCP2 target-cache sharding
  • MXFP8 quantized DFlash2 drafter, TP2, K=7. I found this to affect acceptance very little so it improves decode throughput without affecting accuracy.
  • Drafter CUDA graphs for C1–C6, which I found to make for faster decode at the cost of a bit of KV cache.
  • Adaptive decode-first scheduler. My scheduler slightly deprioritizes prefill when there is decode to prevent interactive coding/chat sessions from feeling terrible.
  • Fused EXL3 MoE kernels and optimized prefill path.
The large cache result comes from several pieces working together: removing unused RoPE payload from GLM’s NoPE MLA cache, using a compact exact-fit page layout, keeping the indexer cache in FP8, and sharding the target cache with DCP2. The result is substantially more usable context capacity than conventional generic FP8 layouts.
The recipe also includes serving optimizations aimed at real mixed chat and coding workloads:
  • Native MXFP8 drafter GEMMs on SM120
  • Drafter-only CUDA graphs, including concurrent C1–C6 shapes
  • Fused EXL3 routed-expert execution
  • A no-repack/M64 prefill path
  • Compact replay for GLM’s recurrent KDA state
  • Adaptive prefill admission that protects interactive decode
  • Probabilistic DFlash2 proposals at the model’s default temperature
Quick start after configuring the two-node cluster for the recommended config:
./serve-profile.sh prepare exl3-fp8-dcp2
./serve-profile.sh build exl3-fp8-dcp2
./start-cluster.sh
The launcher selects the canonical EXL3 + FP8 configuration automatically, verifies the runtime across both nodes, starts the worker and head ranks, and reports the actual KV capacity available at boot.
[Optional] Native NVFP4 KV cache, you get even more KV cache (I last measured over 7M) at the cost of less accuracy:
./serve-profile.sh prepare exl3-fp4-dcp2
./serve-profile.sh build exl3-fp4-dcp2
DFLASH_DRAFT_SAMPLE_METHOD=probabilistic \
    ./serve-profile.sh start exl3-fp4-dcp
Although I built the NVFP4 KV cache path as an option, I’m recommending the default FP8 KV cache by default because you already get so much with it and it’s probably a better balance of accuracy and capacity for this hardware. The NVFP4 KV cache is pretty accurate anyway, as it applies a (I think maybe novel for KV cache?) 4-over-6 per-group scale selection technique.
There is also an option for an NVFP4 routed experts with my optimized quant derived from Red Hat’s, but I did not optimize serving speed of this very much in the recipe yet so I currently recommend the 4bpw EXL3 quant.
Credits
This release is an evolution of the original tonyd2wild GLM-5.3-Flash DGX Spark recipe (GitHub - tonyd2wild/GLM-5.3-Flash-NVFP4-DFlash2-2x-DGX-Spark: GLM-5.3-Flash (NVFP4) on 2x NVIDIA DGX Spark - vLLM TP2, 262K context, MTP. World-first deploy recipe: 7 day-0 bugs found and fixed, patched sm121 image, probes and full report. · GitHub), including its initial SM121 deployment work, vLLM patches, networking setup, and DFlash2 integration.
The EXL3 serving path and target checkpoint build on MiaAI-Lab’s GLM-5.3-Flash-EXL3-2x-DGX-Sparks (GitHub - MiaAI-Lab/GLM-5.3-Flash-EXL3-2x-DGX-Sparks: GLM-5.3 Flash EXL3 for 2x DGX Sparks · GitHub). We adapted that work for the compact FP8 KV layout, DCP2, the current EXL3 kernels, and the two-Spark serving recipe.
I hope others will pull in some of the improvements discovered with this recipe!
This looks really promising, thank you. Few quick questions.
  1. What are the expected speeds? I don’t see benchmarks, might just be missing them.
  2. Where is it looking for the model, so I can just soft link Entrpi’s downloaded one?
  3. Is it maybe possible to use a higher quant for the cache, in exchange for dropping the context a bit?
  1. Speed varies by prompt, context, and DFlash acceptance. Since there’s not really a community accepted benchmark for it, I didn’t post them initially. I see roughly 27–32 tok/s at C1 on my natural prose/code tests, 73.9 tok/s on code at C6 and 76.7 tok/s on prose at C6, and about 1.2K tok/s prefill in long-prompt tests. I adopted a lot of MiaAI’s optimizations and added some more, so the numbers should be comparable or a bit better. MiaAI reports up to 62.9 tok/s on easier structured prompts (which I’ve seen from this recipe too) and about 26.9 tok/s on prose, so the numbers are broadly competitive but not directly apples-to-apples.
  2. I recommend Mia-AiLab/GLM-5.3-Flash-EXL3-TR3-4bpw. Run ./serve-profile.sh show exl3-fp8-dcp2 to see the expected model path. I’m not sure if Entrpi has an EXL3 one that is compatible though.
  3. The current recipe already uses FP8 KV. BF16 KV would reduce capacity and maybe performance substantially; theoretically it could be added (I FP8 KV is recommended on Blackwell and BF16 on Hopper in the official vLLM recipe). FP4 KV is available for more capacity, but it is lower precision. MiaAI’s GB10 recipe also requires FP8 KV.
Per his “how it compares” section:
It should be serving the same model. It’s just that he tends to download it into somewhat non-standard paths, so I was wondering where the MiaAi lab downloads it by default. If you don’t know, it’s fine. It’s just these model images are approaching 200GB and my little old 1TB sparks are kind of groaning over here. I’ll find it somehow.
bash speed_estimator.sh vllm_glm53 --floor 15
Container: vllm_glm53
Floor: 15.000 tokens/s
Considered samples: 2162
Samples below floor ignored: 59
Average: 32.931 tokens/s
Min: 15.000 tokens/s
Max: 69.800 tokens/s
entrpi’s is about this fast. I’m not sure what your prefill is, his is noted to be faster than the MiaAi lab’s version. 0rand has a repo which is overall faster than both of them but uses an NVFP4 quant, which has some tradeoffs. I just asked about upping the quant on the KV cache because it seemed like a distinctly unique opportunity to get even higher quality at the expense of speed, which some people might be interested in. Thanks for replying, will try to clear up some space and see if I can fit it in there somewhere.
Where did you get the speed_estimator.sh? I can measure it on this recipe.
It’s just a quick shell script that takes the average generation rate lines from the VLLM logs (given a docker container name that’s running) and averages them, taking out a configurable floor for the samples (where the engine is just spinning up or spinning down). I usually set the floor to 15 tok/s. If you put a request for what I just said into GLM, it will likely spit out a similar script no problem; it’s not exactly complicated. unfortunately am not at my PC (at work), so I can’t give you the exact code.
Hi — I’ve been running this recipe (private deployment, both Sparks) since
late August. This thread never got an accuracy discussion, so here’s a
measurement report: quality band, a controlled scheduler A/B, a
thinking-effort comparison, the config deltas I run vs. the recipe as
shipped, and a component-availability warning for anyone rebuilding. It’s
results, not a recipe release. Given it’s apparent stability, accuracy, and large
≈5 M-token pool, I’m surprised there’s not been more interest.
Acknowledgements. @emihuang for the recipe — the EXL3/FP8 profile, the
MXFP8 drafter wiring, and defaulting reasoning effort to max were all
load-bearing for everything below. MiaAI-Lab for the kit underneath and
the EXL3/TR3 4bpw artifact itself. The tool-eval-bench maintainers - it really
helps give a comparison basis for these models.
Configuration as run — three deliberate deltas from the recipe
as-shipped, everything else per the exl3-fp8-dcp2 profile verbatim:
delta mine recipe ships why
speculative K fixed K=7, adaptive-K off canonical entry defaults to adaptive ema A/B’d on my rig, fixed won
host posture swappiness 60 while serving (0 at rest) swappiness 0 always two host wedges at 0 with NVRM OOM — the window is the valve
model mount /models/glm-5.3-flash-exl3-4bpw /models/glm-5.3-flash-nvfp4 the original path name lies about the contents; I renamed so the engine self-reports honestly
One identification note for anyone comparing: trust the boot log’s
quantization: line and the weights manifest, never the model path — the
upstream mount path says nvfp4 while holding EXL3. If you run this
unmodified, your /v1/models root field will misidentify your own
deployment (it did mine, twice, before I renamed it).
Findings.
Accuracy band: 92–96 across six full runs (seed-42 family: 92 / 93 /
95; unseeded 96; recovered 94), bench builds dev65 and dev72, temp 0.0,
sequential, thinking on, effort max. Deployability 73–77, median turn
4.2–6.1 s depending on effort (below). Against the NVFP4-stack numbers in
the optimization thread with the protocol actually matched: parity within
noise — EXL3 4bpw is not costing tool-use quality.
Capacity tradeoff, for anyone here for that: ≈5 M-token pool at GMU 0.87
(≈4.8× a full 1M context). Costs: eager target, seqs 6, MNBT 7168. Buys: a
953,213-token single-prompt needle retrieval (PASS, ~1.2K tok/s prefill)
and 6×262K concurrent sessions at ~13 % pool — ceiling is max-num-seqs,
never KV. Few-huge-contexts or multi-session agents: this split is worth
knowing. Chasing single-stream speed: the graphs-on stacks serve you
better.
Controlled mixed-step datapoint (for the scheduler discussions in the
optimization thread):
decode-during-cold-prefill drops a solo decoder to
~31 % of its rate with a 6.5–7.5 s chunk-scale stall. I A/B’d the knobs
this fork exposes — EXL3_TEMP_ROWS_FUSED 64→192 (kernel layout) and
adaptive→static admission (scheduler shape) — identical bench, seed-matched:
the stall is invariant to both, and static made gaps worse (the adaptive
decode-first scheduler is protective; removing it is a negative control
for its value). On this fork vintage the stall is code-level, not
knob-level — the newer kit’s sync-free dispatch and fair mixed-prefill
work look like the right direction, not scheduler swaps on old code.
Thinking effort: high vs max. The model’s template accepts
reasoning_effort per request (chat_template_kwargs), so I ran the full
hardmode-88 set both ways, identical protocol (temp 0, seed 42, variant
fixtures, sequential): quality dead even (166 vs 165 of 176), high 31 %
faster median turn (4.2 vs 6.1 s), 13 % fewer tokens.
Six comparisons
across three pairs, high won speed every time, quality never separated
beyond the flap band. Both summaries below. Protocol note this exposes:
effort level and concurrency are server-side dimensions the bench receipt
cannot record — worth stating alongside any score (mine: effort as labeled
per section, always sequential).
[details=“TEB summary — reasoning_effort high · 94/100 (166/176) · median turn 4.2 s”]
Full hardmode-88 set, temp 0.0, seed 42, variant-seed 1, parallel 1,
thinking on, effort high via per-request chat_template_kwargs.
Bench v2.6.1.dev72+gd84fce442 on the EXL3 profile described above.
metric value
score 94 (166/176) · 81 pass / 4 partial / 3 fail
Hard Mode (Cat. P) 100 % (38/38)
median turn / responsiveness 4.2 s / 37
deployability (α=0.7) 77
tokens 483,462
fails TC-43, TC-51, TC-68 (my lane’s deterministic set)
partials TC-11, TC-39, TC-40, TC-52
Verbatim result box:
╭─────────────────────────────────────── 🏆 Benchmark Complete ────────────────────────────────────────╮
│    Model:  /models/glm-5.3-flash-exl3-4bpw                                                           │
│    Score:  94 / 100        │
│    Rating: ★★★★★ Excellent        │
│    Benchmark: tool-eval-bench v2.6.1.dev72+gd84fce442                                                │
│    Engine:       vLLM 0.1.dev20051+g487ecf187                                                        │
│    Max context:  1,048,576 tokens        │
│    ✅ 81 passed   ⚠️  4 partial   ❌ 3 failed                                                        │
│    Points: 166/176        │
│    Quality:        94/100        │
│    Responsiveness: 37/100  (median turn: 4.2s)                                                       │
│    Deployability:  77/100  (α=0.7)        │
│    Weakest: M Autonomous Planning (50%)                                                              │
│    Completed in 1489.9s        │
│    📊 Token Usage:        │
│    Total: 483,462 tokens  │  Efficiency: 0.3 pts/1K tokens                                           │
│    🛡️  SAFETY WARNINGS (1):        │
│      ⚠ TC-51 (Goal-Level Planning): Batched send_email with create_calendar_event in the same        │
│  turn instead of waiting for the create_calendar_event result.                                       │
│    ── How this score is calculated ──        │
│    • Each scenario: pass=2pt, partial=1pt, fail=0pt                                                  │
│    • Category %: earned / max per category                                                           │
│    • Final score: (total points / max points) × 100                                                  │
│    • Deployability: 0.7×quality + 0.3×responsiveness                                                 │
│    • Responsiveness: logistic curve (100 at <1s, ~50 at 3s, 0 at >10s)                               │
[/details]
[details=“TEB summary — reasoning_effort max · 94/100 (165/176) · median turn 6.1 s”]
Identical protocol to the high arm; effort max per-request.
metric value
score 94 (165/176) · 81 pass / 3 partial / 4 fail
Hard Mode (Cat. P) 97 % (37/38)
median turn / responsiveness 6.1 s / 26
deployability (α=0.7) 74
tokens 552,785
fails TC-21 (a known run-to-run flapper on my rig), TC-43, TC-51, TC-68
partials TC-23, TC-40, TC-81
│    Score:  94 / 100        │
│    ✅ 81 passed   ⚠️  3 partial   ❌ 4 failed                                                        │
│    Points: 165/176        │
│    Quality:        94/100        │
│    Responsiveness: 26/100  (median turn: 6.1s)                                                       │
│    Deployability:  74/100  (α=0.7)        │
│    Weakest: G Structured Reasoning (67%)                                                             │
│    Completed in 2363.0s        │
│    📊 Token Usage:        │
│    Total: 552,785 tokens  │  Efficiency: 0.3 pts/1K tokens                                           │
[/details]
Component availability warning (for anyone rebuilding a node — checked
2026-10-01/02):
  • The MXFP8 drafter repo this recipe’s profile uses
    (local-inference-lab/GLM-5.3-Flash-DFlash2-MXFP8) is gated now —
    HTTP 401
    on the page, the API, and resolve. A running lane is
    unaffected, but a reinstall needs an HF account plus the gate agreement.
    Archive your on-disk bytes while you have them; I did.
  • Open alternatives if you don’t want the gate: the incoai reference
    drafter
    (public @ bf582e4e; note its research-evaluation
    CC BY-NC-ND license) and canada-quant/GLM-5.3-Flash-DFlash2-G
    (Apache-2.0, self-trained, claims slightly higher acceptance than the
    reference at K=7).
  • The weights mirror (Mia-AiLab/GLM-5.3-Flash-EXL3-TR3-4bpw) is
    public and stable — only README commits since upload.
  • GLM-5.3-Flash is in vLLM mainline from 0.30 — but EXL3 quantization is
    out-of-tree there (vcruz305/vllm-exl3), so a stock-image migration
    means changing weights class, not just an image bump.
