I will like to know if its possible to define some device global variables in a host module, which can later be used by device codes i.e global and device subroutines. I will like to know if this is possible normally , and what this compiler errors really mean, its a test code consisting of two modules and the main program as follows
The precision module:
module precision_m
integer , parameter :: singlePrecision = kind (0.0)
integer , parameter :: doublePrecision = kind (0.0d0)
! Comment out one of the lines below
integer , parameter :: fp_kind = singlePrecision
!integer , parameter :: fp_kind = doublePrecision
! This is to enable hybrid algorithms
integer , parameter :: hb_kind = doublePrecision
end module precision_m
The read control file
module test_host_gen
use precision_m
implicit none
real(fp_kind) , device :: D_M_he
real(fp_kind) :: M_he
contains
subroutine read_control_file(ctrl_file)
character(len=100) , intent(in) :: ctrl_file
character(len=100) :: buffer, label
integer :: pos , swch
integer, parameter :: fh = 15
integer :: ios = 0
integer :: line = 0
open(fh, file=ctrl_file)
do while (ios == 0)
read(fh, '(A)', iostat=ios) buffer
if (ios == 0) then
line = line + 1
! Find the first instance of whitespace. Split label and data.
pos = scan(buffer, ' ')
label = buffer(1:pos)
buffer = buffer(pos+1:)
select case (label)
case ('M_he')
read(buffer, *, iostat=ios) M_he
print *, 'Read Mass of Helium M_he : ', M_he
case default
print *, 'Skipping invalid label at line', line
end select
end if
end do
end subroutine read_control_file
end module test_host_gen
The Kernels Module:
module test_global
use test_host_gen
contains
attributes(global) subroutine test_kernel(k_M_he)
real(fp_kind) , device :: k_M_he
k_M_he = D_M_he
end subroutine test_kernel
end module test_global
The main program:
program test
use test_global
implicit none
character(len=100) :: ctrl_file
real(fp_kind) :: tempo
integer :: tmp_int
ctrl_file = "input.txt"
call read_control_file(ctrl_file)
D_M_he = M_he
call test_kernel<<<1,1>>>(k_M_he)
tempo = M_he
! Copy GPU Value
M_he = k_M_he
if (tempo.eq.M_he) print *, 'It works !!!!'
end program test
compiler errors:
pgf90 -g -o testgpu precision_m.o test_host_gen.o test_global.o test.o
test_host_gen.o: In function `..cuda_fortran_constructor_1':
./test_host_gen.CUF:42: undefined reference to `__pgi_cuda_register_fat_binary'
./test_host_gen.CUF:42: undefined reference to `__cudaRegisterVar'
test_global.o: In function `test_global_test_kernel_':
./test_global.CUF:11: undefined reference to `cudaSetupArgument'
./test_global.CUF:11: undefined reference to `cudaLaunch'
test_global.o: In function `..cuda_fortran_constructor_1':
./test_global.CUF:13: undefined reference to `__pgi_cuda_register_fat_binary'
./test_global.CUF:13: undefined reference to `__cudaRegisterFunction'
test.o: In function `test':
./test.CUF:12: undefined reference to `pgf90_dev_alloc04'
./test.CUF:12: undefined reference to `pgf90_dev_symhandle_copyin'
./test.CUF:12: undefined reference to `pgf90_dev_configure_call'
./test.CUF:12: undefined reference to `pgf90_dev_copyout'
./test.CUF:23: undefined reference to `pgf90_dev_dealloc03'
make: *** [test] Error 2
