I’m trying to pass two floating point paramters to a cuda function (d_roverPos, and d_m01)
I did a cudaMalloc on them, and then whenever I get new data, I copy the data to the device using cudaMemcpy and pass the device pointers into the function. I’ve also tried just passing host pointers to the function, which yielded the same results I’m getting. Here’s the code:
extern "C"void cudaCalcFrame(float* roverPos, float* m01, float lambda, float* readBuff, float* writeBuff, int width) {
#ifdef __DEVICE_EMULATION__
printf("roverPosition: (%.3f, %.3f, %3f) Input: (%.3f, %.3f)\n", roverPos[0], roverPos[1], roverPos[2], m01[0], m01[1]);
#endif
// Copy inputs to device
cudaMemcpy((void**)d_roverPos, roverPos, 3*sizeof(float), cudaMemcpyHostToDevice);
cudaMemcpy((void**)d_m01, m01, 2*sizeof(float), cudaMemcpyHostToDevice);
d_cudaCalcFrame <<< *grid, *threads >>> (d_roverPos, d_m01, lambda, readBuff, writeBuff, width);
The above print statement yields:
But in the actual cuda function it prints out as:
Which is clearly incorrect, does anyone know why my data’s getting mangled?
