Global Memory Coalescing Help
Hi everyone,
I’m attempting to coalesce the global memory access for a kernel.
thread size is 16x16.
v is an array of floats of size 64x64 = 4096.
sv is an array in shared memory, of size 17x17 = 289.
In the beginning of the kernel, I do this:
i = (blockDim.x * blockIdx.x + threadIdx.x) + (blockDim.y * blockIdx.y + threadIdx.y) * 64
j = threadIdx.x + (blockDim.x+1) * threadIdx.y
sv[j] = v[i]
if (threadIdx.x == blockDim.x - 1)
  Â sv[j+1] = v[i+1]
if (threadIdx.y == blockDim.y - 1)
  Â sv[j+17] = v[i+64]
Of the 3 memory accesses, the first one and the last one are coalesced. However, I can’t think of any way to coalesce the second access.
It’s hard to explain, but here are my quick thoughts:
Find the formula that describes the relationship of i and j, and only access global memory when threadIdx.x % 16 == globalIndex % 16. To do this, you just need to bias the writes into shared memory differently.
If threadIdx.x == blockDim.x - 1, threadIdx.x is 15.
The second access is uncoalesced because
threadIdx.x == 15
and
15 % 16 == 15
so
(i in threadIdx.x == 15) % 16 == 15
but
((i + 1) in threadIdx.x == 15) % 16 = 0
threadIdx.x == 0 should be writing into that position in shared memory, if I understand correctly.
