I have the following simple code:
#include<stdio.h>
#define BLOCKSIZE_X 32
#define BLOCKSIZE_Y 1
int iDivUp(int a, int b) { return ((a % b) != 0) ? (a / b + 1) : (a / b); }
#define gpuErrchk(ans) { gpuAssert((ans), __FILE__, __LINE__); }
inline void gpuAssert(cudaError_t code, char *file, int line, bool abort=true)
if (code != cudaSuccess)
fprintf(stderr,"GPUassert: %s %s %d\n", cudaGetErrorString(code), file, line);
if (abort) exit(code);
__global__ void kernel0(float *d_a, float *d_b, const unsigned int M, const unsigned int N)
const int tidx = threadIdx.x + blockIdx.x * blockDim.x;
const int tidy = threadIdx.y + blockIdx.y * blockDim.y;
if ((tidx < M)&&(tidy < N)) {
d_b[tidy * M + tidx] = d_a[tidy * M + tidx];
void main()
const unsigned int M = 32;
const unsigned int N = 1;
float *d_a; cudaMalloc((void**)&d_a, M*N*sizeof(float));
float *d_b; cudaMalloc((void**)&d_b, M*N*sizeof(float));
dim3 dimGrid(iDivUp(M, BLOCKSIZE_X), iDivUp(N, BLOCKSIZE_Y));
dim3 dimBlock(BLOCKSIZE_X, BLOCKSIZE_Y);
kernel0<<<dimGrid, dimBlock>>>(d_a, d_b, M, N);
gpuErrchk(cudaPeekAtLastError());
gpuErrchk(cudaDeviceSynchronize());
cudaDeviceReset();
which executes the assignment between two arrays of 32 floats. I’m trying to understand the relation between global memory coalesced accesses and global memory load/store efficiency as well as other metrics/events.
The Visual Profiler shows the following metrics:
Global Memory Load Efficiency = 50%
Global Memory Store Efficiency = 100%
The value of the Global Memory Load Efficiency surprises me. I would have expected 100% efficiency in both the cases since I believe I’m performing a perfectly coalesced memory access. So my question is:
Why do I have a 50% Global Memory Load Efficiency when I’m performing a coalesced memory access and instead I have a 100% Global Memory Store Efficiency?
I have investigated also other metrics/events, which may be useful to be reported:
gld_inst_32bit = 32 (Number of 32-bit global memory load transactions)
gst_inst_32bit = 32 (Number of 32-bit global memory store transactions)
Indeed I’m requesting to load/write 32 floats.
uncached global load transaction = 0 (Number of uncached global load transactions)
l1 global load miss = 2 (Number of global load misses in L1 cache)
The above two events seem to be contradictory, according to my (probably erroneous) understanding. In the case of a l1 cache miss, I would have expected the first event to be different from 0.
gld_request = 1 (Number of executed global load instructions per warp in a SM)
gst_request = 1 (Number of executed global store instructions per warp in a SM)
which seem to be consistent with the fact that I’m performing a perfectly coalesced memory access.
The disassembled code is the following:
/*0000*/ MOV R1, c[0x1][0x100]; /* 0x2800440400005de4 */
/*0008*/ S2R R3, SR_CTAID.Y; /* 0x2c0000009800dc04 */
/*0010*/ S2R R4, SR_TID.Y; /* 0x2c00000088011c04 */
/*0018*/ IMAD R4, R3, c[0x0][0xc], R4; /* 0x2008400030311ca3 */
/*0020*/ S2R R0, SR_CTAID.X; /* 0x2c00000094001c04 */
/*0028*/ ISETP.LT.U32.AND P0, PT, R4, c[0x0][0x2c], PT; /* 0x188e4000b041dc03 */
/*0030*/ S2R R2, SR_TID.X; /* 0x2c00000084009c04 */
/*0038*/ IMAD R0, R0, c[0x0][0x8], R2; /* 0x2004400020001ca3 */
/*0040*/ ISETP.LT.U32.AND P0, PT, R0, c[0x0][0x28], P0; /* 0x18804000a001dc03 */
/*0048*/ @!P0 BRA.U 0x78; /* 0x40000000a000a1e7 */
/*0050*/ @P0 IMAD R2, R4, c[0x0][0x28], R0; /* 0x20004000a04080a3 */
/*0058*/ @P0 ISCADD R0, R2, c[0x0][0x20], 0x2; /* 0x4000400080200043 */
/*0060*/ @P0 ISCADD R2, R2, c[0x0][0x24], 0x2; /* 0x4000400090208043 */
/*0068*/ @P0 LD R0, [R0]; /* 0x8000000000000085 */
/*0070*/ @P0 ST [R2], R0; /* 0x9000000000200085 */
/*0078*/ EXIT; /* 0x8000000000001de7 */
My configuration: CUDA 6.5, GeForce GT540M, Windows 7.
If I increase M from 32 to 64 to launch two blocks and make the two available Streaming Multiprocessors of my card busy, then the Global Memory Load Efficiency turns to 100% and these are the new metrics/events:
gld_inst_32bit = 64
gst_inst_32bit = 64
gld_request = 2
gst_request = 2
The increases of gld_inst_32bit, gst_inst_32bit, gld_request and gst_request are expected and consistent since now I’m loading7storing 64 floats and 2 global memory load/store coalesced requests. But I do not still understand how uncached global load transaction and l1 global load miss can keep the same, while the global memory load throughput changes to provide 100% efficiency.
Results on a Kepler K20c for M=32:
Global Memory Load Efficiency = 100%
gld_inst_32bit = 64
gst_inst_32bit = 64
gld_request = 1
gst_request = 1
uncached global load transaction = 1
l1 global load miss = 0
l1 global load hit = 0
Now the Visual Profiler reports an uncached global load transaction but no l1 global load miss.
