Global Memory
Hi all,
I am trying to declare an huge array on Global Memory:
device float A[51210241024]
but I get this error:
ptxas /tmp/tmpxft_000067c7_00000000-2_XXX.ptx, line 509; �%J�Y: Parsing error near ‘-’: syntax error
ptxas �%J�Y: Ptx assembly aborted due to errors
make: *** [XXX.o] Error 255
The gpu has 4 GB of global memory, and that would be 2GB so I don’t know why that’s happening.
I’ve also tried:
device float A[536870912u]
But nothing change. It seems like there is a limitation of 2GB for an array (when I change float to char I get no errors).
Any idea?
Thank you.
Hi!
What OS are you using?
I also encountered the same error.
It seems we cannot declare an array of size more than 2 GB.
Hi!
It is because of WDDM, if you are using Win Vista/7.
http://forums.nvidia.com/index.php?showtopic=156091&hl=wddm
I am using Ubuntu, but still have the same problem.
