The global pointer like
#define DIM 3
double (*p)[DIM];
does not work well. The memory error as
Failing in Thread:1
call to cuStreamSynchronize returned error 700: Illegal address during kernel execution
arises when the double array is accessed after memory allocation.
The whole code for the error is as follows;
using namespace std;
#define DIM 3
static double (*Position)[DIM];
#pragma acc declare create(Position)const int N=10;
const int W=3;static void allocatePosition( void ){
Position=(double (*)[DIM])malloc(sizeof(double [DIM])*N);
#pragma acc enter data create(Position[0:N][0:DIM])
}static void calculatePosition( void ){
#pragma acc kernels
#pragma acc loop independent
for(int iP=0;iP<N;++iP){
Position[iP][0]=iP/W;
Position[iP][1]=iP%W;
Position[iP][2]=0;
}static void outputPosition( void ){
#pragma acc update host(Position[0:N][0:DIM])
printf("%d: %e %e %e\n",iP,Position[iP][0],Position[iP][1],Position[iP][2]);
}int main(int argc, char *argv){
allocatePosition();
calculatePosition();
outputPosition();
return 0;
