Hi Everone,
I have been facing one strange error in EMMC Xavier NX module at 1.3Gbps. That is when am running my IC in 1.3 Gbps in Xavier Nx sd-card module I can able to read data perfectly but when am reading same set up in xavier NX EMMC module I am facing GLOBAL type:PHY_INTR0 phy:0 error.
Can anyone help me to solve this issue.
I tried increasing pixel and serdes clock but not helping.
Here I have attached my trace log
kworker/0:4-2089 [000] … 695.972254: rtos_queue_send_from_isr_failed: tstamp:22259651103 queue:0x0bcbc160
kworker/0:4-2089 [000] … 695.972256: rtcpu_nvcsi_intr: tstamp:22259653628 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/0:4-2089 [000] … 695.972260: rtcpu_vinotify_event: tstamp:22259692957 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:20810675520 data:0x10000000
kworker/0:4-2089 [000] … 695.972262: rtcpu_vinotify_event: tstamp:22259693117 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:20810683776 data:0x31000001
kworker/0:4-2089 [000] … 695.972263: rtcpu_vinotify_event: tstamp:22259693275 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:20810685952 data:0x07020001
kworker/0:4-2089 [000] … 695.972264: rtcpu_vinotify_event: tstamp:22259693411 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:20810797184 data:0x10000000
kworker/0:4-2089 [000] … 695.972266: rtcpu_vinotify_event: tstamp:22259693567 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:20810805536 data:0x31000002
kworker/0:4-2089 [000] … 696.084197: rtos_queue_peek_from_isr_failed: tstamp:22264171017 queue:0x0bcbcf78
kworker/0:4-2089 [000] … 696.252190: rtos_queue_peek_from_isr_failed: tstamp:22269171020 queue:0x0bcbcf78
kworker/0:4-2089 [000] … 696.420186: rtos_queue_peek_from_isr_failed: tstamp:22274171020 queue:0x0bcbcf78
kworker/0:4-2089 [000] … 696.588180: rtos_queue_peek_from_isr_failed: tstamp:22279171020 queue:0x0bcbcf78
kworker/0:4-2089 [000] … 696.756178: rtos_queue_peek_from_isr_failed: tstamp:22284171021 queue:0x0bcbcf78
kworker/0:4-2089 [000] … 696.924179: rtos_queue_peek_from_isr_failed: tstamp:22289171021 queue:0x0bcbcf78
kworker/0:4-2089 [000] … 697.036183: rtos_queue_peek_from_isr_failed: tstamp:22294171021 queue:0x0bcbcf78
kworker/0:4-2089 [000] … 697.204177: rtos_queue_peek_from_isr_failed: tstamp:22299171025 queue:0x0bcbcf78
kworker/0:4-2089 [000] … 697.372189: rtcpu_nvcsi_intr: tstamp:22303904512 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372194: rtcpu_nvcsi_intr: tstamp:22303904512 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372195: rtcpu_nvcsi_intr: tstamp:22303907712 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372197: rtcpu_nvcsi_intr: tstamp:22303907712 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372198: rtcpu_nvcsi_intr: tstamp:22303910995 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372199: rtcpu_nvcsi_intr: tstamp:22303910995 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372201: rtcpu_nvcsi_intr: tstamp:22303911535 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372202: rtcpu_nvcsi_intr: tstamp:22303914276 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372203: rtcpu_nvcsi_intr: tstamp:22303914276 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372204: rtcpu_nvcsi_intr: tstamp:22303914814 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372205: rtcpu_nvcsi_intr: tstamp:22303917564 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372206: rtcpu_nvcsi_intr: tstamp:22303917564 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372208: rtcpu_nvcsi_intr: tstamp:22303951387 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372209: rtcpu_nvcsi_intr: tstamp:22303951387 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372210: rtcpu_nvcsi_intr: tstamp:22303954585 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372211: rtcpu_nvcsi_intr: tstamp:22303954585 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372212: rtcpu_nvcsi_intr: tstamp:22303955124 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372213: rtcpu_nvcsi_intr: tstamp:22303957870 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372214: rtcpu_nvcsi_intr: tstamp:22303957870 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372215: rtcpu_nvcsi_intr: tstamp:22303958415 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372216: rtcpu_nvcsi_intr: tstamp:22303961154 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372217: rtcpu_nvcsi_intr: tstamp:22303961154 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372218: rtcpu_nvcsi_intr: tstamp:22303961740 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372219: rtcpu_nvcsi_intr: tstamp:22303964434 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372220: rtcpu_nvcsi_intr: tstamp:22303964434 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372221: rtcpu_nvcsi_intr: tstamp:22303998263 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372222: rtcpu_nvcsi_intr: tstamp:22303998263 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372224: rtcpu_nvcsi_intr: tstamp:22304001462 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372225: rtcpu_nvcsi_intr: tstamp:22304001462 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372226: rtcpu_nvcsi_intr: tstamp:22304001999 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372227: rtcpu_nvcsi_intr: tstamp:22304004745 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372228: rtcpu_nvcsi_intr: tstamp:22304004745 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372229: rtcpu_nvcsi_intr: tstamp:22304005286 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372230: rtcpu_nvcsi_intr: tstamp:22304008027 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372231: rtcpu_nvcsi_intr: tstamp:22304008027 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372232: rtcpu_nvcsi_intr: tstamp:22304008564 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372233: rtcpu_nvcsi_intr: tstamp:22304011313 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372277: rtcpu_nvcsi_intr: tstamp:22304011313 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372278: rtcpu_nvcsi_intr: tstamp:22304045138 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372279: rtcpu_nvcsi_intr: tstamp:22304045138 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372280: rtcpu_nvcsi_intr: tstamp:22304048337 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372281: rtcpu_nvcsi_intr: tstamp:22304048337 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372283: rtcpu_nvcsi_intr: tstamp:22304048879 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372284: rtcpu_nvcsi_intr: tstamp:22304051620 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372285: rtcpu_nvcsi_intr: tstamp:22304051620 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372286: rtcpu_nvcsi_intr: tstamp:22304052157 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372287: rtcpu_nvcsi_intr: tstamp:22304054906 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372288: rtcpu_nvcsi_intr: tstamp:22304054906 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372289: rtcpu_nvcsi_intr: tstamp:22304055490 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372290: rtcpu_nvcsi_intr: tstamp:22304058191 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372291: rtcpu_nvcsi_intr: tstamp:22304058191 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372292: rtcpu_nvcsi_intr: tstamp:22304092013 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372293: rtcpu_nvcsi_intr: tstamp:22304092013 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372294: rtcpu_nvcsi_intr: tstamp:22304095212 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372295: rtcpu_nvcsi_intr: tstamp:22304095212 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372297: rtcpu_nvcsi_intr: tstamp:22304095750 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372298: rtcpu_nvcsi_intr: tstamp:22304098498 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372299: rtcpu_nvcsi_intr: tstamp:22304098498 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
kworker/0:4-2089 [000] … 697.372301: rtcpu_nvcsi_intr: tstamp:22304099037 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372302: rtcpu_nvcsi_intr: tstamp:22304101781 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000044
kworker/0:4-2089 [000] … 697.372303: rtcpu_nvcsi_intr: tstamp:22304101781 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001044
