We are facing this issue while interfacing the OS0502A Image sensor with Jetson Xavier NX on MIPI-CSI-C port with 2 lanes configuration.
The image sensor is configured to stream for 2688X1944 resolution in 2 lane mode with 544Mbps Linear10 30fps
cam_trace.log (12.6 MB)
dm.log (176.5 KB)
Any suggestion to try?
hello saravanakumar512,
there’s phy interrupt and it’s the correctable error,
for example,
kworker/0:0-8404 [000] .... 655.773435: rtcpu_nvcsi_intr: tstamp:20814018129 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000042
kworker/0:0-8404 [000] .... 655.773439: rtcpu_nvcsi_intr: tstamp:20814018129 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000042
please examine the signaling,
you may also check IMX219 Raw8 mode on the XavierNX: Disabling CRC - #9 by ShaneCCC to disable ECC/CRC.
thanks
system
closed
#5
