I have been able to install mxnet version 1.4.1 using https://devtalk.nvidia.com/default/topic/1049293/jetson-nano/i-was-unable-to-compile-and-install-mxnet-on-the-jetson-nano-is-there-an-official-installation-tutorial-/post/5326119/#5326119
I am unable to install gluoncv. The cuda version is 10.0. I have tried pip install gluoncv.
Should I do source installation?
Please help. Thanks.
Maybe you can try to build it from source:
git clone https://github.com/dmlc/gluon-cv
cd gluon-cv && python setup.py install --user
Dear AastaLLL,
Yes, building from source indeed works. Thanks for the response!
The prebuilt file is v1.4.0 so it’s more recommended to build mxnet from source with the instructions shared here:
You can check out the v1.4.1 with this command:
git clone https://github.com/apache/incubator-mxnet.git --branch v1.4.1 --recursive
Thank you, I have successfully installed v1.4.1.
