I have code that seems work on Intel GPUs and legacy NVidia cards up to 1080 but fails on RTX4080.
I am using glad to load the OpenGL (4.5) and WGL symbols.
The shader program compiles and links fine:
static const char* vs_source[] = { R"_(
#version 450 core
uniform highp mat4 projection;
out vec2 texCoord;
void main(void)
// using GL_TRIANGLE_FAN
mat4 vertices = {
{-1.0, -1.0, 0.0, 1},
{-1.0, 1.0, 0.0, 1},
{ 1.0, 1.0, 0.0, 1},
{ 1.0, -1.0, 0.0, 1},
mat4x2 texCoords = {
{0.,0.},
{0.,1.},
{1.,1.},
{1.,0.}
texCoord = texCoords[gl_VertexID];
gl_Position = projection * vertices[gl_VertexID];
)_" };
static const char* fs_source[] = { R"(
#version 450 core
// swizzle takes care of converting single channel image data (Red)
// to broadcasting Red to Green and Blue
// can use identity when color channel loaded
uniform mat4 swizzle;
uniform float zoom;
uniform vec2 corner;
uniform lowp vec2 contrast_range;
layout (binding = 0) uniform sampler2D image;
layout (binding = 1) uniform sampler1D offsets;
layout (binding = 2) uniform sampler2D colormap;
in vec2 texCoord;
ivec2 getSampleCoordinates(void)
//vec2 texc = mat2(0,1,1,0) * texCoord;
ivec2 dimensions = textureSize(image, 0);
//int row_offset = int(texelFetch(offsets, int(texc.t * dimensions.y), 0).r);
ivec2 coordinates = ivec2(texCoord.s * dimensions.x /*+ row_offset*/, texCoord.t * dimensions.y);
return coordinates;
void main(void)
vec4 color = texelFetch(image, getSampleCoordinates(), 0);
// swizzle matrix has converted to grayscale
// color.r = (color.r - contrast_range.x) / (contrast_range.y - contrast_range.x);
color.g = color.r;
color.b = color.r;
gl_FragColor = color;
// intialize
m_program = glCreateProgram();
GLuint fs = glCreateShader(GL_FRAGMENT_SHADER);
glShaderSource(fs, 1, fs_source, NULL);
glCompileShader(fs);
CHECK_ERRORS();
GLuint vs = glCreateShader(GL_VERTEX_SHADER);
glShaderSource(vs, 1, vs_source, NULL);
glCompileShader(vs);
CHECK_ERRORS();
glAttachShader(m_program, vs);
glAttachShader(m_program, fs);
glLinkProgram(m_program);
CHECK_ERRORS();
The program fails on every draw command on the RTX4080
#define CHECK_ERRORS() { \
auto error = glGetError(); \
if (error != GL_NO_ERROR) \
stringstream ss; \
ss << __FUNCTION__ << "::" << __LINE__ << "::" << this_thread::get_id() << " OpenGL error: 0x" << std::hex << error; \
std::cerr << ss.str() << "\n"; \
if (!m_dirty && m_dirtyImage.empty()) return;
wglMakeCurrent(m_hdc, m_hRC);
////std::cerr << this_thread::get_id() << " - " << wglMakeCurrent(m_hdc, m_hRC) << "\n";
//CHECK_ERRORS();
glClearColor(0.0f, 0.05f, 0.8f, 1.0f);
CHECK_ERRORS();
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
CHECK_ERRORS();
if (m_program == 0) return;
// FAILS HERE!!!!!!!!!!!!!!!!
glUseProgram(m_program);
CHECK_ERRORS();
// ERROR produces: OpenGLView::OnPaint::565::11716 OpenGL error: 0x502
// only on NVidia RTX4080
if (!m_dirtyImage.empty()) updateImage(m_dirtyImage);
CHECK_ERRORS();
SwapBuffers(m_hdc);
//CHECK_ERRORS();
m_dirty = false;
glUseProgram(0);
//// Allow other rendering contexts to coexist
wglMakeCurrent(NULL, NULL);
I have tried 3 different drivers, but all fail.
The same approach works on RTX4080 if I use GLFW3 for the windows (i.e. same shader program works on GLFW3 but not on MFC).
I need MFC to support a legacy project. Can someone help me figure out a way to make this shader load successfully on the 4080?
