Gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucod e get fail for gv11b
I compiled the source code of the Jetson Xavier NX kernel, following the official tutorial, but the following error appeared after burning the system to the development board. The strange thing is that using the serial port to log in, can run “ls, pwd” and other commands, indicating that my root file system is OK.
The steps are as follows:
  1. Installation environment
sudo apt install build-essential bc libncurses5-dev
  1. Configure environment variables
# The <user_name> has been replaced
export CROSS_COMPILE=/home/<user_name>/NV_Jetson_NX/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
export LOCALVERSION=-tegra
  1. Configure and compile
cd /Linux_for_Tegra/sources/kernel/kernel-4.9
mkdir -p kernel_build
make ARCH=arm64 O=kernel_build tegra_defconfig
make ARCH=arm64 O=kernel_build -j8
  1. Kernel replacement
cp kernel_build/arch/arm64/boot/Image      Linux_for_Tegra/kernel/Image
cp -r kernel_build/arch/arm64/boot/dts/*   Linux_for_Tegra/kernel/dtb/
  1. rootfs
sudo make ARCH=arm64 O=kernel_build modules_install INSTALL_MOD_PATH=Linux_for_Tegra/rootfs/
cd   Linux_for_Tegra/
sudo ./apply_binaries.sh
6.Make brush bag
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_nvme.xml -S 230GiB  --external-only  --showlogs --no-flash jetson-xavier-nx-devkit nvme0n1p1
  1. Burning system
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_nvme.xml -S 230GiB  --erase-all --external-only  --showlogs --flash-only jetson-xavier-nx-devkit nvme0n1p1
Finally, the system can enter the account and password configuration interface, as well as region selection and so on. However, after the loading, the desktop cannot be accessed. The following error is found when the serial port module is used to view system logs:
?[   61.544271] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   61.544465] gk20a 17000000.gv11b: Falling back to user helper
[   61.546671] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   61.546875] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
??[   62.038486] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   62.038679] gk20a 17000000.gv11b: Falling back to user helper
[   62.041035] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   62.041308] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   62.529554] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   62.529748] gk20a 17000000.gv11b: Falling back to user helper
[   62.532470] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   62.532684] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   63.013817] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   63.014010] gk20a 17000000.gv11b: Falling back to user helper
[   63.016464] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   63.016670] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   63.483087] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   63.483281] gk20a 17000000.gv11b: Falling back to user helper
[   63.486843] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   63.487752] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   63.963758] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   63.963956] gk20a 17000000.gv11b: Falling back to user helper
[   63.967242] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   63.967463] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   64.459585] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   64.459778] gk20a 17000000.gv11b: Falling back to user helper
[   64.462230] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   64.462439] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   64.937362] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   64.937552] gk20a 17000000.gv11b: Falling back to user helper
[   64.940076] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   64.940297] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   65.445790] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   65.445978] gk20a 17000000.gv11b: Falling back to user helper
[   65.448362] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   65.448556] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   65.934657] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   65.934845] gk20a 17000000.gv11b: Falling back to user helper
[   65.937318] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   65.937515] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   66.439539] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   66.439728] gk20a 17000000.gv11b: Falling back to user helper
[   66.443127] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   66.443368] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   66.921547] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   66.921737] gk20a 17000000.gv11b: Falling back to user helper
[   66.925364] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   66.925576] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   67.407586] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   67.407782] gk20a 17000000.gv11b: Falling back to user helper
[   67.411064] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   67.411287] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   67.905182] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   67.905370] gk20a 17000000.gv11b: Falling back to user helper
[   67.907667] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   67.907873] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   68.400866] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   68.401057] gk20a 17000000.gv11b: Falling back to user helper
[   68.403382] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   68.403599] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   68.904486] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   68.904675] gk20a 17000000.gv11b: Falling back to user helper
[   68.907289] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   68.907506] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
??[   69.393299] gk20a 17000000.gv11b: Direct firmware load for gv11b/acr_ucode.bin failed with error                    -2
[   69.393488] gk20a 17000000.gv11b: Falling back to user helper
[   69.396136] nvgpu: 17000000.gv11b            gm20b_bootstrap_hs_acr:1279 [ERR]  acr_ucode.bin ucod                   e get fail for gv11b
[   69.396357] nvgpu: 17000000.gv11b            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap fail                   ed
Would the same error happen if you flash the default BSP, instead of the one compiled by yourself?
Also, we no longer maintains kernel 4.9/L4T 32.x, so please try the same workflow on kernel 5.10/L4T 35.x if there is no specific reason you have to use older releases.
Dude, you should reply publicly here instead of in private message…
Do you know what L4T version you are using?
Also, did you make any modification to the kernel source?
L4T R32.6.1 was used without any changes to the kernel source code
Can you try 32.7.4 or 35.4.1?
Is is a DevKit or a custom carrier board?
Problem solved, jetpack4.6 supports 32.6.1, while I use jetpack4.6.4 supports 32.7.4. I was compiling the 32.6.1 kernel on jetpack4.6.4 when this error occurred. It should also be noted that jetpack4.6 and jetpack4.6.4 are two completely different versions, and 4.6.4 has a lot of changes. Suggest to check “https://developer.nvidia.com/” and “https://developer.nvidia.com/embedded/jetpack-sdk-46” to understand the relationship between different jetpack version.
I have another problem, I bought a new core board to replace the original core board, found that the new core board can not enter the system, but the old core board can enter. Or the core board can not be replaced directly, ask what kind of operations need to be carried out?
Though you are supposed to file another topic, I’ll still answer here.
If you only buy a module itself instead of with a DevKit, the QSPI memory on the module is empty, meaning there is no bootloader stuff on it.
Do something like this:
sudo ./flash.sh -r jetson-xavier-nx-devkit-qspi internal
