Thank you for the reply. It finally worked , once i started using the virtual game pad for moving the carter robot around. Before i was using the mouse .
But now there is a crash in gmapping library
#0 0x00007ffff42ea650 in GMapping::ScanMatcher::registerScan(GMapping::Map<GMapping::PointAccumulator, GMapping::HierarchicalArray2DGMapping::PointAccumulator, true>&, GMapping::orientedpoint<double, double> const&, double const*) ()
from /home/renu/.cache/bazel/_bazel_renu/315f47e548a43e388ce68c76071bbb3c/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/apps/navsim/navsim_gmapping.runfiles/com_nvidia_isaac//packages_x86_64/lidar_slam/libg_mapping_module.so
#1 0x00007ffff42dfb21 in GMapping::GridSlamProcessor::processScan(GMapping::RangeReading const&, int) ()
#2 0x00007ffff42d8f0f in isaac::lidar_slam::GMapping::tick() ()
#3 0x00005555555d4a76 in std::_Function_handler<void (), isaac::alice::CodeletBackend::addToScheduler(isaac::alice::CodeletBackend::CodeletSchedule*)::{lambda()#1}>::_M_invoke(std::_Any_data const&) ()
#4 0x000055555563e4f6 in isaac::scheduler::Job::run() ()
#5 0x0000555555570a0c in isaac::scheduler::ExecutionGroup::Worker::main(isaac::scheduler::ExecutionGroup*) ()
#6 0x00007ffff59796df in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#7 0x00007ffff5c4c6db in start_thread (arg=0x7fffb1675700)
