I am currently developing a GMSL camera driver using the AR0234 sensor with the MAX9295A serializer and MAX96716A deserializer.
The /dev/video0 device node is successfully created, but when I run the following command:
v4l2-ctl -d /dev/video0
–set-fmt-video=width=1920,height=1080,pixelformat=UYVY
–stream-mmap --stream-count=1 --verbose
I encounter the following error:
kworker/1:3-125 [001] .... 1244.611279: rtcpu_string: tstamp:39551616065 id:0x04010000 str:"VM0 deactivating."
v4l2-ctl-3688 [002] .... 1251.858423: tegra_channel_open: vi-output, des_ch_0
v4l2-ctl-3688 [002] .... 1252.060958: tegra_channel_set_power: des_ch_0 : 0x1
v4l2-ctl-3688 [002] .... 1252.060969: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3688 [002] .... 1252.060971: csi_s_power: enable : 0x1
v4l2-ctl-3688 [002] .... 1252.061640: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
v4l2-ctl-3688 [002] .... 1252.070374: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-3688 [002] .... 1252.074435: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3688 [002] .... 1252.074454: csi_s_stream: enable : 0x1
kworker/1:3-125 [001] .... 1252.075082: rtcpu_string: tstamp:39786317749 id:0x04010000 str:"VM0 activating."
kworker/1:3-125 [001] .... 1252.131075: rtcpu_vinotify_event: tstamp:39786966933 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1273166885024 data:0x719d580010000000
kworker/1:3-125 [001] .... 1252.131080: rtcpu_vinotify_event: tstamp:39786967221 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1273166894784 data:0x0000000031000001
kworker/1:3-125 [001] .... 1252.131081: rtcpu_vinotify_event: tstamp:39786967518 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1273166985824 data:0x719d550010000000
kworker/1:3-125 [001] .... 1252.131081: rtcpu_vinotify_event: tstamp:39786967763 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1273166995744 data:0x0000000031000002
v4l2-ctl-3688 [002] .... 1252.228611: tegra_channel_set_stream: des_ch_0 : 0x1
kworker/1:3-125 [001] .... 1252.299084: rtcpu_nvcsi_intr: tstamp:39792307507 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x01c00000
kworker/1:3-125 [001] .... 1252.299089: rtcpu_nvcsi_intr: tstamp:39792308274 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299090: rtcpu_nvcsi_intr: tstamp:39792308830 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299090: rtcpu_nvcsi_intr: tstamp:39792309369 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299090: rtcpu_nvcsi_intr: tstamp:39792309905 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299090: rtcpu_nvcsi_intr: tstamp:39792310438 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299091: rtcpu_nvcsi_intr: tstamp:39792310975 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299091: rtcpu_nvcsi_intr: tstamp:39792311513 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299091: rtcpu_nvcsi_intr: tstamp:39792312059 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299091: rtcpu_nvcsi_intr: tstamp:39792312626 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299092: rtcpu_nvcsi_intr: tstamp:39792313156 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299092: rtcpu_nvcsi_intr: tstamp:39792313688 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299092: rtcpu_nvcsi_intr: tstamp:39792314299 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299092: rtcpu_nvcsi_intr: tstamp:39792314835 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299092: rtcpu_nvcsi_intr: tstamp:39792315368 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299093: rtcpu_nvcsi_intr: tstamp:39792315944 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299093: rtcpu_nvcsi_intr: tstamp:39792316478 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299093: rtcpu_nvcsi_intr: tstamp:39792317010 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299093: rtcpu_nvcsi_intr: tstamp:39792317612 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299094: rtcpu_nvcsi_intr: tstamp:39792318147 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299094: rtcpu_nvcsi_intr: tstamp:39792318676 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299094: rtcpu_nvcsi_intr: tstamp:39792319288 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299094: rtcpu_nvcsi_intr: tstamp:39792319883 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299095: rtcpu_nvcsi_intr: tstamp:39792320438 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299095: rtcpu_nvcsi_intr: tstamp:39792320971 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299095: rtcpu_nvcsi_intr: tstamp:39792321504 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299095: rtcpu_nvcsi_intr: tstamp:39792322037 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299095: rtcpu_nvcsi_intr: tstamp:39792322621 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299095: rtcpu_nvcsi_intr: tstamp:39792323152 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299096: rtcpu_nvcsi_intr: tstamp:39792323685 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299096: rtcpu_nvcsi_intr: tstamp:39792324310 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299096: rtcpu_nvcsi_intr: tstamp:39792324844 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299096: rtcpu_nvcsi_intr: tstamp:39792325377 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299096: rtcpu_nvcsi_intr: tstamp:39792325948 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299097: rtcpu_nvcsi_intr: tstamp:39792326482 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299097: rtcpu_nvcsi_intr: tstamp:39792327016 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:3-125 [001] .... 1252.299098: rtcpu_vinotify_error: tstamp:39792331228 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1273354480960 data:0x0000000000000010
kworker/1:3-125 [001] .... 1252.299099: rtcpu_vinotify_event: tstamp:39792392549 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1273354480960 data:0x0000000000000010
kworker/1:3-125 [001] .... 1252.299099: rtcpu_vinotify_event: tstamp:39792934555 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273364197600 data:0x0000000000000011
kworker/1:3-125 [001] .... 1252.299099: rtcpu_vinotify_event: tstamp:39792934850 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1273364197696 data:0x0000000800000000
kworker/1:3-125 [001] .... 1252.299099: rtcpu_vinotify_event: tstamp:39792935105 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1273364198592 data:0x0000000000000001
kworker/1:3-125 [001] .... 1252.299100: rtcpu_vinotify_event: tstamp:39792935390 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1273364239072 data:0x0000000008020001
kworker/1:3-125 [001] .... 1252.299100: rtcpu_vinotify_event: tstamp:39793119389 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1273378290336 data:0x0000000000000021
kworker/1:3-125 [001] .... 1252.299100: rtcpu_vinotify_event: tstamp:39793119673 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:0 vi_tstamp:1273378290336 data:0x0423200001000000
kworker/1:3-125 [001] .... 1252.299100: rtcpu_vinotify_event: tstamp:39793119918 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1273378357088 data:0x0000000001020001
kworker/1:3-125 [001] .... 1252.299101: rtcpu_vinotify_event: tstamp:39793120202 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1273378290432 data:0x0000000800000000
kworker/1:3-125 [001] .... 1252.299101: rtcpu_vinotify_event: tstamp:39793120446 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1273378677696 data:0x719d580010000000
kworker/1:3-125 [001] .... 1252.299101: rtcpu_vinotify_event: tstamp:39793120722 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1273378721056 data:0x0000000031000003
kworker/1:3-125 [001] .... 1252.299101: rtcpu_vinotify_event: tstamp:39793120963 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273379574432 data:0x0000000000000011
kworker/1:3-125 [001] .... 1252.355067: rtcpu_vinotify_event: tstamp:39793640639 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1273379574560 data:0x0000000800000000
kworker/1:3-125 [001] .... 1252.355072: rtcpu_vinotify_event: tstamp:39793640897 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1273379575424 data:0x0000000000000001
kworker/1:3-125 [001] .... 1252.355073: rtcpu_vinotify_event: tstamp:39793641197 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1273379628320 data:0x0000000008020002
kworker/1:3-125 [001] .... 1252.355073: rtcpu_vinotify_event: tstamp:39793641442 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1273393673760 data:0x0000000000000021
kworker/1:3-125 [001] .... 1252.355073: rtcpu_vinotify_event: tstamp:39793641725 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:0 vi_tstamp:1273393673760 data:0x0424200001000000
kworker/1:3-125 [001] .... 1252.355073: rtcpu_vinotify_event: tstamp:39793641976 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1273393740512 data:0x0000000001020002
kworker/1:3-125 [001] .... 1252.355074: rtcpu_vinotify_event: tstamp:39793642260 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1273393673856 data:0x0000000800000000
kworker/1:3-125 [001] .... 1252.355074: rtcpu_vinotify_event: tstamp:39793642505 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1273394055520 data:0x719d550010000000
kworker/1:3-125 [001] .... 1252.355074: rtcpu_vinotify_event: tstamp:39793642785 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1273394098848 data:0x0000000031000004
kworker/1:3-125 [001] .... 1252.355074: rtcpu_vinotify_event: tstamp:39793643029 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273394964832 data:0x0000000000000011
kworker/1:3-125 [001] .... 1252.355074: rtcpu_vinotify_event: tstamp:39793643309 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1273394964928 data:0x0000000800000000
kworker/1:3-125 [001] .... 1252.355075: rtcpu_vinotify_event: tstamp:39793643553 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1273394965824 data:0x0000000000000001
kworker/1:3-125 [001] .... 1252.355075: rtcpu_vinotify_event: tstamp:39793643833 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1273395006368 data:0x0000000008020003
kworker/1:3-125 [001] .... 1252.355075: rtcpu_vinotify_event: tstamp:39794042308 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1273409057216 data:0x0000000000000021
kworker/1:3-125 [001] .... 1252.355075: rtcpu_vinotify_event: tstamp:39794042592 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:0 vi_tstamp:1273409057216 data:0x0423200001000000
kworker/1:3-125 [001] .... 1252.355075: rtcpu_vinotify_event: tstamp:39794042841 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1273409123968 data:0x0000000001020003
kworker/1:3-125 [001] .... 1252.355076: rtcpu_vinotify_error: tstamp:39794558733 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273425740992 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.355076: rtcpu_vinotify_event: tstamp:39794563393 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1273409057280 data:0x0000000800000000
kworker/1:3-125 [001] .... 1252.355076: rtcpu_vinotify_event: tstamp:39794563646 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273410348736 data:0x0000000000000011
kworker/1:3-125 [001] .... 1252.355076: rtcpu_vinotify_event: tstamp:39794563942 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1273410348832 data:0x0000000800000000
kworker/1:3-125 [001] .... 1252.355077: rtcpu_vinotify_event: tstamp:39794564192 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1273410349728 data:0x0000000000000001
kworker/1:3-125 [001] .... 1252.355077: rtcpu_vinotify_event: tstamp:39794564485 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1273410390272 data:0x0000000008020004
kworker/1:3-125 [001] .... 1252.355077: rtcpu_vinotify_event: tstamp:39794564729 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1273424440608 data:0x0000000000000021
kworker/1:3-125 [001] .... 1252.355078: rtcpu_vinotify_event: tstamp:39794565016 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:0 vi_tstamp:1273424440640 data:0x0423200001000000
kworker/1:3-125 [001] .... 1252.355079: rtcpu_vinotify_event: tstamp:39794565267 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1273424507392 data:0x0000000001020004
kworker/1:3-125 [001] .... 1252.355080: rtcpu_vinotify_event: tstamp:39794565560 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1273424440736 data:0x0000000800000000
kworker/1:3-125 [001] .... 1252.355080: rtcpu_vinotify_event: tstamp:39794565801 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273425740000 data:0x0000000000000011
kworker/1:3-125 [001] .... 1252.355080: rtcpu_vinotify_event: tstamp:39794566089 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273425740992 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.355080: rtcpu_vinotify_error: tstamp:39795039131 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273441112064 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.355081: rtcpu_vinotify_event: tstamp:39795104808 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1273439824064 data:0x0000000000000021
kworker/1:3-125 [001] .... 1252.355081: rtcpu_vinotify_event: tstamp:39795105088 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273441111072 data:0x0000000000000011
kworker/1:3-125 [001] .... 1252.355081: rtcpu_vinotify_event: tstamp:39795105333 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273441112064 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.411068: rtcpu_vinotify_error: tstamp:39795520160 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273456500256 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.411075: rtcpu_vinotify_event: tstamp:39795521242 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1273455207488 data:0x0000000000000021
kworker/1:3-125 [001] .... 1252.411075: rtcpu_vinotify_event: tstamp:39795521487 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273456499264 data:0x0000000000000011
kworker/1:3-125 [001] .... 1252.411075: rtcpu_vinotify_error: tstamp:39796000877 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273471889728 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.411075: rtcpu_vinotify_event: tstamp:39796027041 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273456500256 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.411076: rtcpu_vinotify_event: tstamp:39796027283 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1273470590944 data:0x0000000000000021
kworker/1:3-125 [001] .... 1252.411076: rtcpu_vinotify_event: tstamp:39796027558 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273471888768 data:0x0000000000000011
kworker/1:3-125 [001] .... 1252.411076: rtcpu_vinotify_event: tstamp:39796027802 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273471889728 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.411076: rtcpu_vinotify_error: tstamp:39796481701 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273487276256 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.411076: rtcpu_vinotify_event: tstamp:39796569642 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1273485974336 data:0x0000000000000021
kworker/1:3-125 [001] .... 1252.411077: rtcpu_vinotify_event: tstamp:39796569887 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273487275264 data:0x0000000000000011
kworker/1:3-125 [001] .... 1252.411077: rtcpu_vinotify_event: tstamp:39796570174 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273487276256 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.411077: rtcpu_vinotify_error: tstamp:39796962378 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273502658016 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.467064: rtcpu_vinotify_event: tstamp:39797112118 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1273501357792 data:0x0000000000000021
kworker/1:3-125 [001] .... 1252.467068: rtcpu_vinotify_event: tstamp:39797112400 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273502657024 data:0x0000000000000011
kworker/1:3-125 [001] .... 1252.467068: rtcpu_vinotify_event: tstamp:39797112644 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273502658016 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.467069: rtcpu_vinotify_error: tstamp:39797442840 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1273518032640 data:0x00000000000003c9
kworker/1:3-125 [001] .... 1252.467069: rtcpu_vinotify_event: tstamp:39797654662 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1273516741216 data:0x0000000000000021
kworker/1:3-125 [001] .... 1252.467069: rtcpu_vinotify_event: tstamp:39797654909 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1273518031648 data:0x0000000000000011
video info
Streaming is not working.
root@sstd-desktop:/home/sstd# uname -a
Linux sstd-desktop 5.10.104-tegra #401 SMP PREEMPT Thu May 7 02:10:33 KST 2026 aarch64 aarch64 aarch64 GNU/Linux
Jetpack_5.1.1_l4t_35.3.1
current.dts.txt (417.9 KB)
Get the trace log by below command.
sudo su
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 3 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
v4l2-ctl --stream-mmap -c bypass_mode=0
cat /sys/kernel/debug/tracing/trace
Boost the clocks to verify if the improper pix_clk_hz cause the short frame.
If still see the CHANSEL_SHORT_FRAME in the trace log that tell the sensor output size doesn’t expected the driver reported.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
I have attached the results. Thank you in advance.
v4l2-ctl-3169 [005] .... 1652.229689: tegra_channel_open: vi-output, des_ch_0
v4l2-ctl-3169 [005] .... 1652.432280: tegra_channel_set_power: des_ch_0 : 0x1
v4l2-ctl-3169 [005] .... 1652.432294: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3169 [005] .... 1652.432296: csi_s_power: enable : 0x1
v4l2-ctl-3169 [005] .... 1652.433580: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
v4l2-ctl-3169 [005] .... 1652.441611: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-3169 [000] .... 1652.446163: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3169 [000] .... 1652.446179: csi_s_stream: enable : 0x1
kworker/1:0-3059 [001] .... 1652.480396: rtcpu_string: tstamp:52367527287 id:0x04010000 str:"VM0 activating."
kworker/1:0-3059 [001] .... 1652.480405: rtcpu_vinotify_event: tstamp:52368193424 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1675766414464 data:0x719d580010000000
kworker/1:0-3059 [001] .... 1652.480406: rtcpu_vinotify_event: tstamp:52368193708 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1675766424192 data:0x0000000031000001
kworker/1:0-3059 [001] .... 1652.480408: rtcpu_vinotify_event: tstamp:52368194003 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1675766507744 data:0x719d550010000000
kworker/1:0-3059 [001] .... 1652.480408: rtcpu_vinotify_event: tstamp:52368194259 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1675766517632 data:0x0000000031000002
v4l2-ctl-3169 [000] .... 1652.600468: tegra_channel_set_stream: des_ch_0 : 0x1
kworker/1:0-3059 [001] .... 1652.656394: rtcpu_nvcsi_intr: tstamp:52373374578 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x01c00000
kworker/1:0-3059 [001] .... 1652.656401: rtcpu_nvcsi_intr: tstamp:52373375338 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656401: rtcpu_nvcsi_intr: tstamp:52373375898 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656401: rtcpu_nvcsi_intr: tstamp:52373376439 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656402: rtcpu_nvcsi_intr: tstamp:52373376973 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656402: rtcpu_nvcsi_intr: tstamp:52373377502 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656402: rtcpu_nvcsi_intr: tstamp:52373378031 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656403: rtcpu_nvcsi_intr: tstamp:52373378573 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656403: rtcpu_nvcsi_intr: tstamp:52373379115 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656405: rtcpu_nvcsi_intr: tstamp:52373379644 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656405: rtcpu_nvcsi_intr: tstamp:52373380207 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656406: rtcpu_nvcsi_intr: tstamp:52373380741 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656406: rtcpu_nvcsi_intr: tstamp:52373381274 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656407: rtcpu_nvcsi_intr: tstamp:52373381886 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656407: rtcpu_nvcsi_intr: tstamp:52373382419 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656407: rtcpu_nvcsi_intr: tstamp:52373382952 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656408: rtcpu_nvcsi_intr: tstamp:52373383533 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656408: rtcpu_nvcsi_intr: tstamp:52373384067 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656409: rtcpu_nvcsi_intr: tstamp:52373384596 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656409: rtcpu_nvcsi_intr: tstamp:52373385205 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656409: rtcpu_nvcsi_intr: tstamp:52373385741 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656410: rtcpu_nvcsi_intr: tstamp:52373386274 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656410: rtcpu_nvcsi_intr: tstamp:52373386855 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656410: rtcpu_nvcsi_intr: tstamp:52373387388 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656410: rtcpu_nvcsi_intr: tstamp:52373387930 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656411: rtcpu_nvcsi_intr: tstamp:52373388533 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656411: rtcpu_nvcsi_intr: tstamp:52373389067 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656411: rtcpu_nvcsi_intr: tstamp:52373389600 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656412: rtcpu_nvcsi_intr: tstamp:52373390177 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656412: rtcpu_nvcsi_intr: tstamp:52373390710 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656412: rtcpu_nvcsi_intr: tstamp:52373391243 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656413: rtcpu_nvcsi_intr: tstamp:52373391776 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656413: rtcpu_nvcsi_intr: tstamp:52373392317 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656413: rtcpu_nvcsi_intr: tstamp:52373392847 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656414: rtcpu_nvcsi_intr: tstamp:52373393378 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656414: rtcpu_nvcsi_intr: tstamp:52373393970 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656414: rtcpu_nvcsi_intr: tstamp:52373394504 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656415: rtcpu_nvcsi_intr: tstamp:52373395037 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656415: rtcpu_nvcsi_intr: tstamp:52373395610 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656416: rtcpu_nvcsi_intr: tstamp:52373396143 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656416: rtcpu_nvcsi_intr: tstamp:52373396680 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656417: rtcpu_nvcsi_intr: tstamp:52373397271 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/1:0-3059 [001] .... 1652.656417: rtcpu_vinotify_error: tstamp:52373401305 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1675948723424 data:0x0000000000000010
kworker/1:0-3059 [001] .... 1652.656419: rtcpu_vinotify_event: tstamp:52373619040 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1675948723424 data:0x0000000000000010
kworker/1:0-3059 [001] .... 1652.656419: rtcpu_vinotify_event: tstamp:52374152471 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1675957236032 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.656420: rtcpu_vinotify_event: tstamp:52374152771 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1675957236160 data:0x0000000800000000
kworker/1:0-3059 [001] .... 1652.656420: rtcpu_vinotify_event: tstamp:52374153022 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1675957236800 data:0x0000000000000001
kworker/1:0-3059 [001] .... 1652.656420: rtcpu_vinotify_event: tstamp:52374153301 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1675957277536 data:0x0000000008020001
kworker/1:0-3059 [001] .... 1652.656421: rtcpu_vinotify_event: tstamp:52374153603 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1675971333632 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.656421: rtcpu_vinotify_event: tstamp:52374153885 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:0 vi_tstamp:1675971333664 data:0x0424200001000000
kworker/1:0-3059 [001] .... 1652.656422: rtcpu_vinotify_event: tstamp:52374154133 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1675971400672 data:0x0000000001020001
kworker/1:0-3059 [001] .... 1652.656422: rtcpu_vinotify_event: tstamp:52374154416 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1675971333760 data:0x0000000800000000
kworker/1:0-3059 [001] .... 1652.656422: rtcpu_vinotify_event: tstamp:52374154659 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1675971698336 data:0x719d580010000000
kworker/1:0-3059 [001] .... 1652.656423: rtcpu_vinotify_event: tstamp:52374154936 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1675971741728 data:0x0000000031000003
kworker/1:0-3059 [001] .... 1652.656423: rtcpu_vinotify_event: tstamp:52374155175 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1675972631392 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.712386: rtcpu_vinotify_event: tstamp:52374649139 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1675972631520 data:0x0000000800000000
kworker/1:0-3059 [001] .... 1652.712392: rtcpu_vinotify_event: tstamp:52374649394 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1675972632160 data:0x0000000000000001
kworker/1:0-3059 [001] .... 1652.712393: rtcpu_vinotify_event: tstamp:52374649674 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1675972685280 data:0x0000000008020002
kworker/1:0-3059 [001] .... 1652.712393: rtcpu_vinotify_event: tstamp:52374649914 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1675986717056 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.712393: rtcpu_vinotify_event: tstamp:52374650202 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:0 vi_tstamp:1675986717088 data:0x0423200001000000
kworker/1:0-3059 [001] .... 1652.712394: rtcpu_vinotify_event: tstamp:52374650453 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1675986783872 data:0x0000000001020002
kworker/1:0-3059 [001] .... 1652.712394: rtcpu_vinotify_event: tstamp:52374650737 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1675986717152 data:0x0000000800000000
kworker/1:0-3059 [001] .... 1652.712394: rtcpu_vinotify_event: tstamp:52374650985 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1675987113728 data:0x719d550010000000
kworker/1:0-3059 [001] .... 1652.712395: rtcpu_vinotify_event: tstamp:52374651268 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1675987157088 data:0x0000000031000004
kworker/1:0-3059 [001] .... 1652.712395: rtcpu_vinotify_event: tstamp:52374651514 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1675988008256 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.712395: rtcpu_vinotify_event: tstamp:52374651797 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1675988008352 data:0x0000000800000000
kworker/1:0-3059 [001] .... 1652.712396: rtcpu_vinotify_event: tstamp:52374652043 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1675988009024 data:0x0000000000000001
kworker/1:0-3059 [001] .... 1652.712396: rtcpu_vinotify_event: tstamp:52374652321 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1675988049824 data:0x0000000008020003
kworker/1:0-3059 [001] .... 1652.712396: rtcpu_vinotify_event: tstamp:52375074941 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676002100448 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.712397: rtcpu_vinotify_event: tstamp:52375075227 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:0 vi_tstamp:1676002100480 data:0x0423200001000000
kworker/1:0-3059 [001] .... 1652.712398: rtcpu_vinotify_event: tstamp:52375075478 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1676002167232 data:0x0000000001020003
kworker/1:0-3059 [001] .... 1652.712399: rtcpu_vinotify_event: tstamp:52375572305 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1676002100544 data:0x0000000800000000
kworker/1:0-3059 [001] .... 1652.712399: rtcpu_vinotify_event: tstamp:52375572561 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676003395552 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.712399: rtcpu_vinotify_event: tstamp:52375572864 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1676003395648 data:0x0000000800000000
kworker/1:0-3059 [001] .... 1652.712400: rtcpu_vinotify_event: tstamp:52375573114 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1676003396288 data:0x0000000000000001
kworker/1:0-3059 [001] .... 1652.712400: rtcpu_vinotify_event: tstamp:52375573415 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1676003437056 data:0x0000000008020004
kworker/1:0-3059 [001] .... 1652.712400: rtcpu_vinotify_event: tstamp:52375573656 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676017483840 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.712401: rtcpu_vinotify_event: tstamp:52375573940 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:0 vi_tstamp:1676017483840 data:0x0423200001000000
kworker/1:0-3059 [001] .... 1652.712401: rtcpu_vinotify_event: tstamp:52375574185 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1676017550592 data:0x0000000001020004
kworker/1:0-3059 [001] .... 1652.712401: rtcpu_vinotify_event: tstamp:52375574469 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1676017483936 data:0x0000000800000000
kworker/1:0-3059 [001] .... 1652.712402: rtcpu_vinotify_error: tstamp:52375591541 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676018789024 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.712402: rtcpu_vinotify_error: tstamp:52376071711 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676034156256 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.712403: rtcpu_vinotify_event: tstamp:52376114561 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676018788288 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.712403: rtcpu_vinotify_event: tstamp:52376114845 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676018789024 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.712403: rtcpu_vinotify_event: tstamp:52376115084 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676032867200 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.712404: rtcpu_vinotify_event: tstamp:52376115364 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676034155456 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.712404: rtcpu_vinotify_event: tstamp:52376115608 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676034156256 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.768383: rtcpu_vinotify_error: tstamp:52376552593 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676049537920 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.768389: rtcpu_vinotify_event: tstamp:52376553669 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676048250592 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.768389: rtcpu_vinotify_event: tstamp:52376553912 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676049537184 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.768390: rtcpu_vinotify_error: tstamp:52377033210 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676064924256 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.768390: rtcpu_vinotify_event: tstamp:52377091187 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676049537920 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.768390: rtcpu_vinotify_event: tstamp:52377091431 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676063633984 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.768391: rtcpu_vinotify_event: tstamp:52377091715 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676064923520 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.768391: rtcpu_vinotify_event: tstamp:52377091958 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676064924256 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.768392: rtcpu_vinotify_error: tstamp:52377514100 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676080312928 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.768392: rtcpu_vinotify_event: tstamp:52377633664 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676079017376 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.768392: rtcpu_vinotify_event: tstamp:52377633909 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676080312160 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.768393: rtcpu_vinotify_event: tstamp:52377634198 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676080312928 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.824540: rtcpu_vinotify_error: tstamp:52377994550 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676095687200 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.824546: rtcpu_vinotify_event: tstamp:52378176200 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676094400768 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.824546: rtcpu_vinotify_event: tstamp:52378176486 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676095686432 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.824547: rtcpu_vinotify_event: tstamp:52378176733 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676095687200 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.824547: rtcpu_vinotify_error: tstamp:52378475474 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676111076928 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.824547: rtcpu_vinotify_event: tstamp:52378718743 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676109784160 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.824548: rtcpu_vinotify_event: tstamp:52378718988 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676111076160 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.824548: rtcpu_vinotify_event: tstamp:52378719276 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676111076928 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.824549: rtcpu_vinotify_error: tstamp:52378956982 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676126478368 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.824549: rtcpu_vinotify_event: tstamp:52378958047 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676125167552 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.824550: rtcpu_vinotify_event: tstamp:52378958326 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676126477632 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.824550: rtcpu_vinotify_event: tstamp:52378958569 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676126478368 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.824551: rtcpu_vinotify_error: tstamp:52379437086 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676141846368 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.824551: rtcpu_vinotify_event: tstamp:52379477978 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676140550976 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.824551: rtcpu_vinotify_event: tstamp:52379478219 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676141845600 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.824552: rtcpu_vinotify_event: tstamp:52379478497 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676141846368 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.880375: rtcpu_vinotify_error: tstamp:52379917575 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676157224032 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.880379: rtcpu_vinotify_event: tstamp:52380020526 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676155934336 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.880380: rtcpu_vinotify_event: tstamp:52380020801 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676157223296 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.880380: rtcpu_vinotify_event: tstamp:52380021043 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676157224032 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.880380: rtcpu_vinotify_error: tstamp:52380398366 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676172607904 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.880380: rtcpu_vinotify_event: tstamp:52380563070 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676171317760 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.880381: rtcpu_vinotify_event: tstamp:52380563315 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676172607136 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.880381: rtcpu_vinotify_event: tstamp:52380563603 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676172607904 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.880381: rtcpu_vinotify_error: tstamp:52380879144 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676187994016 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.880381: rtcpu_vinotify_event: tstamp:52381105610 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676186701184 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.880381: rtcpu_vinotify_event: tstamp:52381105889 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676187993248 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.880382: rtcpu_vinotify_event: tstamp:52381106134 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676187994016 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.880382: rtcpu_vinotify_error: tstamp:52381359587 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676203368416 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.936542: rtcpu_vinotify_event: tstamp:52381648148 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676202084544 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.936550: rtcpu_vinotify_event: tstamp:52381648398 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676203367680 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.936550: rtcpu_vinotify_event: tstamp:52381648691 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676203368416 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.936550: rtcpu_vinotify_event: tstamp:52381798870 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676217467968 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.936552: rtcpu_vinotify_error: tstamp:52381840496 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676218757600 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.936552: rtcpu_vinotify_event: tstamp:52382298894 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676218756832 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.936553: rtcpu_vinotify_event: tstamp:52382299144 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676218757600 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.936553: rtcpu_vinotify_event: tstamp:52382299428 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676232851392 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.936554: rtcpu_vinotify_error: tstamp:52382321479 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676234149024 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.936554: rtcpu_vinotify_error: tstamp:52382801986 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676249525216 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.936555: rtcpu_vinotify_event: tstamp:52382842309 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676234148224 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.936555: rtcpu_vinotify_event: tstamp:52382842603 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676234149024 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.936556: rtcpu_vinotify_event: tstamp:52382842846 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676248234752 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.936556: rtcpu_vinotify_event: tstamp:52382843125 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676249524448 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.936557: rtcpu_vinotify_event: tstamp:52382843367 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676249525216 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.992609: rtcpu_vinotify_error: tstamp:52383282705 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676264908224 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.992615: rtcpu_vinotify_event: tstamp:52383384790 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676263618176 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.992615: rtcpu_vinotify_event: tstamp:52383385033 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676264907488 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.992616: rtcpu_vinotify_event: tstamp:52383385321 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676264908224 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.992617: rtcpu_vinotify_error: tstamp:52383763248 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676280281024 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.992618: rtcpu_vinotify_event: tstamp:52383927332 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676279001568 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.992618: rtcpu_vinotify_event: tstamp:52383927614 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676280280256 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.992619: rtcpu_vinotify_event: tstamp:52383927860 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676280281024 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.992620: rtcpu_vinotify_error: tstamp:52384244377 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676295675136 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.992620: rtcpu_vinotify_event: tstamp:52384245446 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676294384992 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.992621: rtcpu_vinotify_event: tstamp:52384245689 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676295674336 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.992621: rtcpu_vinotify_error: tstamp:52384724812 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676311055648 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.992622: rtcpu_vinotify_event: tstamp:52384740907 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676295675136 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1652.992622: rtcpu_vinotify_event: tstamp:52384741151 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676309768384 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1652.992622: rtcpu_vinotify_event: tstamp:52384741432 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676311054880 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1652.992622: rtcpu_vinotify_event: tstamp:52384741676 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676311055648 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.048375: rtcpu_vinotify_error: tstamp:52385206055 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676326455456 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.048384: rtcpu_vinotify_event: tstamp:52385283450 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676325151808 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.048385: rtcpu_vinotify_event: tstamp:52385283696 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676326454720 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.048385: rtcpu_vinotify_event: tstamp:52385283987 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676326455456 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.048386: rtcpu_vinotify_error: tstamp:52385686300 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676341821280 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.048386: rtcpu_vinotify_event: tstamp:52385825976 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676340535200 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.048387: rtcpu_vinotify_event: tstamp:52385826255 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676341820512 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.048387: rtcpu_vinotify_event: tstamp:52385826499 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676341821280 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.048388: rtcpu_vinotify_error: tstamp:52386167397 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676357218304 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.048388: rtcpu_vinotify_event: tstamp:52386368520 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676355918624 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.048389: rtcpu_vinotify_event: tstamp:52386368765 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676357217536 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.048389: rtcpu_vinotify_event: tstamp:52386369045 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676357218304 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.048390: rtcpu_vinotify_error: tstamp:52386648059 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676372592768 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.048390: rtcpu_vinotify_event: tstamp:52386649132 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676371302016 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.048391: rtcpu_vinotify_event: tstamp:52386649412 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676372592000 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.048391: rtcpu_vinotify_event: tstamp:52386649661 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676372592768 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.104534: rtcpu_vinotify_error: tstamp:52387128345 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676387968608 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.104543: rtcpu_vinotify_event: tstamp:52387182100 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676386685408 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.104544: rtcpu_vinotify_event: tstamp:52387182344 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676387967872 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.104544: rtcpu_vinotify_event: tstamp:52387182624 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676387968608 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.104544: rtcpu_vinotify_error: tstamp:52387609612 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676403369152 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.104545: rtcpu_vinotify_event: tstamp:52387724643 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676402068832 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.104545: rtcpu_vinotify_event: tstamp:52387724927 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676403368384 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.104546: rtcpu_vinotify_event: tstamp:52387725175 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676403369152 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.104546: rtcpu_vinotify_error: tstamp:52388089958 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676418740224 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.104546: rtcpu_vinotify_event: tstamp:52388267182 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676417452224 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.104547: rtcpu_vinotify_event: tstamp:52388267428 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676418739488 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.104547: rtcpu_vinotify_event: tstamp:52388267710 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676418740224 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.160366: rtcpu_vinotify_error: tstamp:52388570583 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676434120192 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.160370: rtcpu_vinotify_event: tstamp:52388809784 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676432835616 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.160370: rtcpu_vinotify_event: tstamp:52388810066 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676434119456 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.160371: rtcpu_vinotify_event: tstamp:52388810308 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676434120192 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.160371: rtcpu_vinotify_error: tstamp:52389051547 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676449511104 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.160371: rtcpu_vinotify_event: tstamp:52389352256 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676448219008 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.160371: rtcpu_vinotify_event: tstamp:52389352501 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676449510400 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.160371: rtcpu_vinotify_event: tstamp:52389352780 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676449511104 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.160372: rtcpu_vinotify_event: tstamp:52389490573 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676463602432 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.160372: rtcpu_vinotify_error: tstamp:52389532610 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676464905248 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.160372: rtcpu_vinotify_event: tstamp:52390003009 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676464904512 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.160372: rtcpu_vinotify_event: tstamp:52390003254 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676464905248 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.160372: rtcpu_vinotify_event: tstamp:52390003529 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676478985824 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.160372: rtcpu_vinotify_error: tstamp:52390012913 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676480274944 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.216532: rtcpu_vinotify_error: tstamp:52390493782 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676495662336 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.216541: rtcpu_vinotify_event: tstamp:52390546361 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676480274208 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.216542: rtcpu_vinotify_event: tstamp:52390546654 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676480274944 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.216542: rtcpu_vinotify_event: tstamp:52390546899 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676494369216 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.216542: rtcpu_vinotify_event: tstamp:52390547170 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676495661600 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.216543: rtcpu_vinotify_event: tstamp:52390547414 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676495662336 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.216543: rtcpu_vinotify_error: tstamp:52390974624 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676511049600 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.216543: rtcpu_vinotify_event: tstamp:52391088901 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676509752640 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.216544: rtcpu_vinotify_event: tstamp:52391089145 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676511048864 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.216544: rtcpu_vinotify_event: tstamp:52391089425 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676511049600 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.216545: rtcpu_vinotify_error: tstamp:52391455391 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676526434368 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.216545: rtcpu_vinotify_event: tstamp:52391631438 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676525136032 data:0x0000000000000021
kworker/1:0-3059 [001] .... 1653.216545: rtcpu_vinotify_event: tstamp:52391631719 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1676526433632 data:0x0000000000000011
kworker/1:0-3059 [001] .... 1653.216546: rtcpu_vinotify_event: tstamp:52391631964 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676526434368 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.272364: rtcpu_vinotify_error: tstamp:52391936062 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x02 frame:0 vi_tstamp:1676541807200 data:0x00000000000003c9
kworker/1:0-3059 [001] .... 1653.272368: rtcpu_vinotify_event: tstamp:52391937125 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1676540519456 data:0x0000000000000021
Does the CHANSEL_NOMATCH error prevent streaming? I’m encountering this error, but while streaming fails on my current setup, it works fine on the Xavier despite the same error appearing.
The key point could be the CHANSEL_SHORT_FRAME
