i want to split camera signals to a second px2.
Is there any solution available?
how is it solved inside the px2 to split the signals to two of the quad-deserializers?
Dear carsten.birke,
May I know why you need to split camera signals to a second DPX2? Thanks.
Dear carsten,
May I know if you managed to spit a single GMSL camera to 2 DPX2s? Did you try using a fakra splitter such as the one linked here [url]Fakra C Male Plug to 2x SMB Female 5005 RG174 Y Type Conversion Radio Splitter Combined Extension Cable 15cm/30cm/50cm For Car|Connectors| - AliExpress? How do you manage the power supply to the camera?
Dear SteveNV,
We have 2 DPX2s that run separate modules on both DPX2s, but only one set of cameras. We would greatly appreciate your opinion on a possible solution.
Thank you.
Regards,
Linn
