Hi,experts
I am using GMSL camera with xavier. The GMSL data is transmitted over 15m coax cables. Use v4l2-ctl to capture the image, it stucks after a while. But it works well with 5m or shorter cables.
Here is the trace log.
camera.log (6.6 MB)
kworker/1:0-18 [001] .... 411.818977: rtcpu_vinotify_event: tstamp:13344431468 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:13344052115 data:0x00000000
kworker/1:0-18 [001] .... 411.818977: rtcpu_vinotify_event: tstamp:13344431593 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:14692826272 data:0x00021ab1
kworker/1:0-18 [001] .... 411.818977: rtcpu_vinotify_event: tstamp:13344431735 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:14693053120 data:0x10000000
kworker/1:0-18 [001] .... 411.818977: rtcpu_vinotify_event: tstamp:13344431859 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:14693069024 data:0x31001ab2
kworker/1:0-18 [001] .... 411.818978: rtcpu_vinotify_event: tstamp:13344432000 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:14693073312 data:0x07021ab2
kworker/1:0-18 [001] .... 411.818978: rtcpu_vinotify_event: tstamp:13344432125 tag:FS channel:0x01 frame:0 vi_tstamp:13344079257 data:0x00000012
kworker/1:0-18 [001] .... 411.818978: rtcpu_vinotify_event: tstamp:13344432266 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:13344079258 data:0x00000000
kworker/1:0-18 [001] .... 411.818978: rtcpu_vinotify_event: tstamp:13344432388 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:13344094439 data:0x00000001
kworker/1:0-18 [001] .... 411.818978: rtcpu_vinotify_event: tstamp:13344432530 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:14694163776 data:0x08021ab2
kworker/1:0-18 [001] .... 411.818978: rtcpu_vinotify_event: tstamp:13344432654 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:13344234406 data:0x00970200
kworker/1:0-18 [001] .... 411.818978: rtcpu_vinotify_event: tstamp:13344432797 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:14698644512 data:0x01021ab2
kworker/1:0-18 [001] .... 411.818979: rtcpu_vinotify_event: tstamp:13345095426 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:13345093641 data:0x04370202
kworker/1:0-18 [001] .... 411.818979: rtcpu_vinotify_event: tstamp:13345095573 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:14726140032 data:0x01021ab2
kworker/1:0-18 [001] .... 411.818979: rtcpu_vinotify_event: tstamp:13345095699 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:13345093658 data:0x00000000
kworker/1:0-18 [001] .... 411.818980: rtcpu_vinotify_error: tstamp:13345137641 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13345135984 data:0x000003c9
kworker/1:0-18 [001] .... 411.818981: rtcpu_vinotify_event: tstamp:13345489174 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:14726145376 data:0x02021ab2
kworker/1:0-18 [001] .... 411.818982: rtcpu_vinotify_event: tstamp:13345489301 tag:FE channel:0x01 frame:0 vi_tstamp:13345093659 data:0x00000022
kworker/1:0-18 [001] .... 411.818982: rtcpu_vinotify_event: tstamp:13345489445 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:13345093661 data:0x00000000
kworker/1:0-18 [001] .... 411.818982: rtcpu_vinotify_event: tstamp:13345489569 tag:FS channel:0x01 frame:0 vi_tstamp:13345120803 data:0x00000012
kworker/1:0-18 [001] .... 411.818982: rtcpu_vinotify_event: tstamp:13345489709 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13345135984 data:0x000003c9
kworker/1:0-18 [001] .... 411.818984: rtos_queue_peek_from_isr_failed: tstamp:13345649692 queue:0x0bcbb8b8
kworker/1:0-18 [001] .... 411.874969: rtcpu_vinotify_error: tstamp:13346179188 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13346177530 data:0x000003c9
kworker/1:0-18 [001] .... 411.874970: rtcpu_vinotify_event: tstamp:13346302928 tag:FE channel:0x01 frame:0 vi_tstamp:13346135206 data:0x00000022
kworker/1:0-18 [001] .... 411.874970: rtcpu_vinotify_event: tstamp:13346303072 tag:FS channel:0x01 frame:0 vi_tstamp:13346162349 data:0x00000012
kworker/1:0-18 [001] .... 411.874971: rtcpu_vinotify_event: tstamp:13346303202 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13346177530 data:0x000003c9
kworker/1:0-18 [001] .... 411.874971: rtcpu_vinotify_error: tstamp:13347220731 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13347219075 data:0x000003c9
kworker/1:0-18 [001] .... 411.874971: rtcpu_vinotify_event: tstamp:13347523663 tag:FE channel:0x01 frame:0 vi_tstamp:13347176750 data:0x00000022
kworker/1:0-18 [001] .... 411.874971: rtcpu_vinotify_event: tstamp:13347523789 tag:FS channel:0x01 frame:0 vi_tstamp:13347203896 data:0x00000012
kworker/1:0-18 [001] .... 411.874972: rtcpu_vinotify_event: tstamp:13347523931 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13347219075 data:0x000003c9
kworker/1:0-18 [001] .... 411.930981: rtcpu_vinotify_error: tstamp:13348262274 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13348260621 data:0x000003c9
kworker/1:0-18 [001] .... 411.930983: rtcpu_vinotify_event: tstamp:13348337813 tag:FE channel:0x01 frame:0 vi_tstamp:13348218296 data:0x00000022
kworker/1:0-18 [001] .... 411.930983: rtcpu_vinotify_event: tstamp:13348337957 tag:FS channel:0x01 frame:0 vi_tstamp:13348245442 data:0x00000012
kworker/1:0-18 [001] .... 411.930983: rtcpu_vinotify_event: tstamp:13348338084 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13348260621 data:0x000003c9
kworker/1:0-18 [001] .... 411.930983: rtcpu_vinotify_event: tstamp:13349288371 tag:FE channel:0x01 frame:0 vi_tstamp:13349259841 data:0x00000022
kworker/1:0-18 [001] .... 411.930984: rtcpu_vinotify_event: tstamp:13349288494 tag:FS channel:0x01 frame:0 vi_tstamp:13349286989 data:0x00000012
kworker/1:0-18 [001] .... 411.930984: rtcpu_vinotify_error: tstamp:13349303808 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13349302167 data:0x000003c9
kworker/1:0-18 [001] .... 411.986995: rtcpu_vinotify_event: tstamp:13349680268 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13349302167 data:0x000003c9
kworker/1:0-18 [001] .... 411.986996: rtcpu_vinotify_error: tstamp:13350345368 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13350343715 data:0x000003c9
kworker/1:0-18 [001] .... 411.986997: rtcpu_vinotify_event: tstamp:13350494414 tag:FE channel:0x01 frame:0 vi_tstamp:13350301388 data:0x00000022
kworker/1:0-18 [001] .... 411.986997: rtcpu_vinotify_event: tstamp:13350494558 tag:FS channel:0x01 frame:0 vi_tstamp:13350328534 data:0x00000012
kworker/1:0-18 [001] .... 411.986997: rtcpu_vinotify_event: tstamp:13350494686 tag:CHANSEL_NOMATCH channel:0x44 frame:0 vi_tstamp:13350343715 data:0x000003c9
