I am using a GMSL camera with Xavier NX based embedded device. By using the below terminal command, I am able to launch gstreamer display of the camera output.
I now want to run the gscam node for launching the same with ROS, although do not understand what the environment variable should be set as before running the rosrun gscam gscam command.
Hoping to get some assistance for the same.
Thanks for getting back and sharing the resources.
In the link provided, I did not find the the solution for what I am looking for. Have I missed out on something?
