Hi all,
We are using a Jetson Xavier NX with a custom carrier board and a custom camera with Omnivision sensor and GMSL2 MAX9295/MAX9296 SerDes. And we have the current situation:
Camera without GMSL2: We are able to capture without problems in the Jetson board
Camera with GMSL2 and Test Pattern enabled in the sensor: We are able to capture the test pattern properly, at the resolution and framerate configured, which make us think the GMSL2 bridge is properly configured.
Camera with GMSL2 enabling capture from sensor: Here is the problem, we are able to capture just a few frames in the Jetson board until it stops receiving images. We are using the same configuration used in 1)
Looks like the issue with 3) might be related to the serdes_pixel_clock or the deskew configuration on the deserializer. Have anyone seen something similar? Looks like in Jetpack 5.x the pixel_clock configuration is pickier, do you have any recommended settings? We are trying to capture 3840x2160@30 RAW12
Thanks in advance.
