Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hi. I had previously posted here about a link lock failure for MAX96712. I did not receive an answer from Nvidia before my post was automatically closed. Can I please get more information from Nvidia about possible mitigations for this issue?
We notice rebooting the target has fixed the issue
So Nvidia has done independent testing and is able to replicate this issue? Rebooting isn’t a resolution, it’s a workaround.
As mentioned in my last post, I dug a bit into the MAX96712 deserializer driver in the SDK and I see a TODO comment (cdi_max96712.c line 2583) mentioning that the link lock may take >100ms intermittently. I wonder if this may have something to do with this issue?
Hi @jmanning2,
Just confirming if You received the camera drivers from quanta?
A bug is filed internally for tracking the issue. I will keep you updated here and seek the requested info from you.
The issue does not look like related to link lock time. We already using 500ms.
If you can share any repro code/steps it would help the to debug.
And gotcha, I was just assuming that could be related given the syslog entry about link lock not detected.
As far as repro, I haven’t been able to nail down criteria to reproduce. It seems to happen very intermittently, we’re working to try and track the frequency/conditions better.
Dear @jmanning2,
Can you check the power of deserializer(use i2cget) when this issue occur. It could be problem with that.
