I am still pretty new to CUDA, trying to figure out what kind of application this can be used for. What I would like to do is realtime audio/synthesis under MIDI-control, so I started out studying what kind of timeframe would be possible? Ideally kernels should run for (at most) a millisecond at a time to have reasonably low latencies and leave enough room to have graphics updating as well.
At first this didn’t look too good. With a plain vanilla desktop kernel, about 20% of the time was spent on uploading a small fragment of data representative of the keyboard state. Upgrading the kernel to 2.6.24.7-rt17 doubled the throughput but most importantly: Jumping out of Gnome then quadrupled the throughput? Modifying the bandwithTest to ask for high priority realtime performance shaved off yet another 20%, so now the test can upload some 10Kbyte of data in just 0.02 milliseconds rather than the original 0.2 milliseconds. That should be good enough, I think …
But what I wonder is: What is up with Gnome? X by itself isn’t degrading performance, nor is a lightweight environment like IceWM.
mvh // Jens M Andreasen
[using a silent 8400GS/g98]
Regarding the slowdown -
Could it be that your Gnome is using OpenGL to draw windows? This is on by default in some distros nowadays. The setting is in the Appearance control panel IIRC.
No. I don’t think so. I just tried out a few more window managers, and surprisingly my all time favourite WindowMaker shows the same symptom as Gnome, whereas blackbox/fluxbox are as invisible as working directly on the console.
Xfce has its own way of (not) working: The first run is high performing but on the second - or no later than the third run - performance has degraded by 90% back to 0.2 milliseconds/minimal transfer
It sounds like the commonality here is the windows manager with compositing support are slower, while those without compositing support are faster. This is basically what kristleifur suggested was the problem.
Does the slow down persist if you explicitly disable the Composite extension in your X configuration ?
Kristleifur, it may not be the WM alone that is playing …
Opening up with only FluxBox and an xterm, the machine will let me have the front seat, and pretty much run it like as if I owned it. Starting OpenOffice.Draw and letting that one quietly hang around is also fine. Hoovering with the mouse in its drawing area - this updates two positional indicators, left and top - immediately brings back the 10x penalty on host-to-device I experienced in Gnome as well as WindowMaker.
The gotcha: All the little nifty toys one might have showing time, CPU, network usage and whatnot.
While I was at it, I came to think of that FlightGear has a builtin benchmark showing frames rendered per second. Wouldn’t it be nice to know - not only how much we are being disturbed, but also how much we are disturbing others? With all settings as default first-time-user I had a healthy 50fps. Running the CUDA bandwidthTest in parallel dropped the fps down 20% to 40, and left me again with 5 minimal htod per millisecond, indicative of 20% GPU. I think this is mostly good - that all clock cycles are more/less accounted for and nothing gets swallowed in some unknown void.
[i]
Edit: No wait, I am confused and that conclusion is wrong. The 20% performance drop in the competing application relates to 5 htod’s of which only one would be needed in a real application. So perhaps an 8% penalty altogether for getting data both in and out, once per millisecond?
[/i]
# The command in question. From the console, running as root with high priority:
./bandwidthTest --memory=pinned --htod --mode=range --start=1024 --end=10240 --increment=1024
Range Mode
Host to Device Bandwidth for Pinned memory
Transfer Size (Bytes) Bandwidth(MB/s)
1024 54.6
2048 111.6
3072 161.9
4096 213.5
5120 253.0
6144 295.9
7168 322.4
8192 383.0
9216 424.6
10240 454.2
# The same from Gnome, with lots of little applets running as well:
1024 4.6
2048 9.2
3072 13.8
4096 18.4
5120 22.8
6144 27.4
7168 32.2
8192 36.6
9216 41.1
10240 45.4
If anybody here has (the slightly better) 8500 or 9400GT, could they perhaps post some numbers for comparison?
