gnu c lib log2
My program use log2().
pgCC didn’t find log2() in math.h.
How to solve this problem?
Hi YJS -
I think you’ll find the log2 function in the libm library. If you add -lm to your link line, the compiler driver should find it for you.
-dave
-lm didn’t solve the problem.
log2() comes from c99 according to some book.
Even pgCC use -c9x,nothing change.
Can you post the compiler/link line and error messages? If you have a pointer to the source, that would be helpful too.
“fingers.cc” ,line 45 : error:identifier “log2” is undefined
fingerCount=(int)(ceil(log2(vsEstimateCount)));
Hi YJS -
Can you try compiling this with pgCC -D_GNU_SOURCE and see if that helps and gives you the right answer?
-dave
#include <stdio.h>
#include <math.h>
main ()
int fingerCount;
int vsEstimateCount;
vsEstimateCount=64;
fingerCount=(int(ceil(log2(vsEstimateCount))));
printf(“fingerCount=%d\n”,fingerCount);
pgcc -D_GNU_SOURCE finger.cc
a.out
fingerCount=6
It works.
How did you know that?
Thx.
Hi yjs -
I think what happens is that log2 is part of the ISOC99 standard and I believe it is defined in mathcalls.h. To include it, features.h, when given that _GNU_SOURCE flag I think set the _USE_ISOC99 flag for the rest of the includes. And then some where the compile includes something to start the chain of events. I think GNU is waiting for wider adoption of ISOC99 before including it by default, at least that is my understanding.
It looks like the funtion is in the libm.a library - just a matter of getting the definition introduced to your routine. So you were on the right path initially looking for it in the header file. Once I saw it was a compile error and not a link error I remembered reading something about this.
Glad it’s working for you.
-dave
