LD_LIBRARY_PATH has no effect on compilation, it only controls how shared libraries are located at runtime. Check the value of CUDA_INSTALL_PATH defined in C/common/common.mk. You can change it in that file or just do
Ok. well, I’m till stumped on this, its a little bit beyond my debugging and linux capabilities. Even a suggestion as to what man pages to read would be helpful at this point. Really, anything.
You should see something like this (using the 3.1 SDK on 64 bit Ubuntu 9.04):
avidday@cuda:/opt/cuda-3.1/sdk/C/src/deviceQuery$ nvcc -I../../../shared/inc -L../../../shared/lib/ deviceQuery.cpp -lshrutil_x86_64 -o deviceQuery
deviceQuery.cpp:126:11: warning: extra tokens at end of #else directive
deviceQuery.cpp:135:11: warning: extra tokens at end of #else directive
avidday@cuda:/opt/cuda-3.1/sdk/C/src/deviceQuery$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
There are 2 devices supporting CUDA
Device 0: "GeForce GTX 470"
CUDA Driver Version: 3.20
CUDA Runtime Version: 3.10
CUDA Capability Major revision number: 2
CUDA Capability Minor revision number: 0
Total amount of global memory: 1341849600 bytes
Number of multiprocessors: 14
Number of cores: 448
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Clock rate: 1.22 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: No
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Concurrent kernel execution: Yes
Device has ECC support enabled: No
Device 1: "GeForce GTX 275"
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 3
Total amount of global memory: 938803200 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Texture alignment: 256 bytes
Clock rate: 1.46 GHz
Run time limit on kernels: Yes
Integrated: No
Compute mode: Prohibited (no host thread can use this device)
Concurrent kernel execution: No
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 3.20, CUDA Runtime Version = 3.10, NumDevs = 2, Device = GeForce GTX 470, Device = GeForce GTX 275
PASSED
If that doesn’t work, then something is broken with your SDK installation. If it does, then the common.mk file in your SDK needs some changes.
Warp size: 32
Integrated: No
Warp size: 32
Integrated: No
PASSED
That is helpful. In attempting to execute that instruction, I realized that my SDK directory is configured differently : the source isn’t in a separate “C” directory and its “common”, not “shared”. I realize now that I’m using an older project directory, but this machine must be set up for a more recent installation. Therefore, I assume that all the makefiles are slightly wrong in my projects folder, for the current version.
So, thanks again for the help. by the way, this is what happens when I run a variation of your suggestion :
$ nvcc -I../../common/inc -L../../common/lib/ deviceQuery.cpp -lshrutil_x86_64 -o deviceQuery
deviceQuery.cpp: In function ‘int main(int, char**)’:
deviceQuery.cpp:109: warning: format ‘%u’ expects type ‘unsigned int’, but argument 2 has type ‘size_t’
deviceQuery.cpp:114: warning: format ‘%u’ expects type ‘unsigned int’, but argument 2 has type ‘size_t’
deviceQuery.cpp:115: warning: format ‘%u’ expects type ‘unsigned int’, but argument 2 has type ‘size_t’
deviceQuery.cpp:127: warning: format ‘%u’ expects type ‘unsigned int’, but argument 2 has type ‘size_t’
deviceQuery.cpp:128: warning: format ‘%u’ expects type ‘unsigned int’, but argument 2 has type ‘size_t’
/usr/bin/ld: cannot find -lshrutil_x86_64
collect2: ld returned 1 exit status
Let me know if there is anything else obviously wrong. For now, I will try to track down which version of CUDA is installed and build an example from_that_version to see if things are working.
