Thanks. I have attached everything below.
My training command:
tlt-train faster_rcnn -e /workspace/data/models/tlt_resnet50_faster_rcnn_v1/train.txt -r /workspace/data/models/tlt_resnet50_faster_rcnn/trained/2020-25-03 --gpus 1 -k KEY
My training spec (Which i forked from the detecnet example and modified for paths and dataset config):
model_config {
pretrained_model_file: “/workspace/data/models/tlt_resnet50_faster_rcnn_v1/resnet50.hdf5”
num_layers: 50
use_batch_norm: true
activation {
activation_type: “relu”
dropout_rate: 0.1
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
arch: “resnet”
bbox_rasterizer_config {
target_class_config {
key: “vehicle”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4
cov_radius_y: 0.4
bbox_min_radius: 1.0
key: “person”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.67
postprocessing_config {
key: “vehicle”
value {
clustering_config {
coverage_threshold: 0.005
dbscan_eps: 0.15
dbscan_min_samples: 0.05
minimum_bounding_box_height: 20
key: “person”
value {
clustering_config {
dbscan_eps: 0.15
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.05
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.9999
min_objective_weight: 0.0001
training_config {
batch_size_per_gpu: 16
num_epochs: 120
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-6
max_learning_rate: 5e-4
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-9
optimizer {
adam {
epsilon: 1e-08
beta1: 0.9
beta2: 0.999
cost_scaling {
enabled: False
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 5
augmentation_config {
preprocessing {
output_image_width: 768
output_image_height: 768
min_bbox_width: 2.0
min_bbox_height: 2.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.2
contrast_scale_max: 0.1
contrast_center: 0.5
evaluation_config {
validation_period_during_training: 5
first_validation_epoch: 45
minimum_detection_ground_truth_overlap {
key: “vehicle”
value: 0.5
key: “person”
value: 0.5
evaluation_box_config {
key: “vehicle”
value {
minimum_height: 4
maximum_height: 9999
minimum_width: 4
maximum_width: 9999
key: “person”
value {
minimum_height: 4
minimum_width: 4
maximum_width: 9999
average_precision_mode: INTEGRATE
dataset_config {
data_sources {
tfrecords_path: “/workspace/data/records/kitti2*”
image_directory_path: “/data/stanford/kitti2”
image_extension: “jpg”
target_class_mapping {
key: “bus”
value: “vehicle”
key: “cart”
value: “vehicle”
key: “pedestrian”
value: “person”
key: “biker”
value: “person”
key: “skater”
value: “person”
key: “car”
value: “vehicle”
validation_fold: 0
Th full log:
Using TensorFlow backend.
2020-03-26 08:22:43.480895: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2020-03-26 08:22:44.349956: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:998] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-03-26 08:22:44.365751: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x666adc0 executing computations on platform CUDA. Devices:
2020-03-26 08:22:44.365792: I tensorflow/compiler/xla/service/service.cc:158] StreamExecutor device (0): Tesla P100-PCIE-16GB, Compute Capability 6.0
2020-03-26 08:22:44.770783: I tensorflow/core/platform/profile_utils/cpu_utils.cc:94] CPU Frequency: 2300000000 Hz
2020-03-26 08:22:44.771152: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x6781d30 executing computations on platform Host. Devices:
2020-03-26 08:22:44.771201: I tensorflow/compiler/xla/service/service.cc:158] StreamExecutor device (0): ,
2020-03-26 08:22:44.771414: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1433] Found device 0 with properties:
name: Tesla P100-PCIE-16GB major: 6 minor: 0 memoryClockRate(GHz): 1.3285
pciBusID: 0000:00:04.0
totalMemory: 15.90GiB freeMemory: 15.64GiB
2020-03-26 08:22:44.771442: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1512] Adding visible gpu devices: 0
2020-03-26 08:22:44.781802: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-03-26 08:22:44.781838: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990] 0
2020-03-26 08:22:44.781865: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1003] 0: N
2020-03-26 08:22:44.781955: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 15216 MB memory) → physical GPU (device: 0, name: Tesla P100-PCIE-16GB, pci bus id: 0000:00:04.0, compute capability: 6.0)
File “/usr/local/bin/tlt-train-g1”, line 10, in
sys.exit(main())
File “./common/magnet_train.py”, line 30, in main
File “./faster_rcnn/scripts/train.py”, line 49, in main
File “./faster_rcnn/spec_loader/spec_loader.py”, line 55, in load_experiment_spec
File “./faster_rcnn/spec_loader/spec_loader.py”, line 31, in _load_proto
File “/usr/local/lib/python2.7/dist-packages/google/protobuf/text_format.py”, line 690, in Merge
allow_unknown_field=allow_unknown_field)
File “/usr/local/lib/python2.7/dist-packages/google/protobuf/text_format.py”, line 757, in MergeLines
return parser.MergeLines(lines, message)
File “/usr/local/lib/python2.7/dist-packages/google/protobuf/text_format.py”, line 782, in MergeLines
self._ParseOrMerge(lines, message)
File “/usr/local/lib/python2.7/dist-packages/google/protobuf/text_format.py”, line 804, in _ParseOrMerge
self._MergeField(tokenizer, message)
File “/usr/local/lib/python2.7/dist-packages/google/protobuf/text_format.py”, line 896, in _MergeField
(message_descriptor.full_name, name))
google.protobuf.text_format.ParseError: 1:1 : Message type “Experiment” has no field named “Skip”.
