SDKM_logs_JetPack_6.2_Linux_for_Jetson_Orin_Nano_[8GB_developer_kit_version]_2025-03-14_11-07-50.zip (191.2 KB)
Already tried:
- Changed different USB ports, USB cables (Type-C, Type-A), even changed to another PC.
- Disable autosuspend on host PC with below command:
$ sudo -s
$ echo -1 > /sys/module/usbcore/parameters/autosuspend
- Not use VM
Please help to check with the enclosed logfile.
Based on your log, we find it might be a firewall issue.
Could you try to disable the firewall and flash your device again?
Thanks for reply.
I’ve disable the firewall by issue:
$ sudo ufw disable
But the errors remain.
Anyway I’ve change the way of program the FW via micro-SD card.
system
Closed
6
