got problem on Fortran acc coding
Dear Sir,
I got the compiler error information as below:
    430, Accelerator region ignored
    436, Accelerator restriction: loop contains multi-level induction variable
    437, Accelerator restriction: multilevel induction variable: ia
    439, Accelerator restriction: multilevel induction variable: ii_k
    461, Accelerator restriction: loop contains multi-level induction variable
    462, Accelerator restriction: multilevel induction variable: i_k
    481, Accelerator restriction: an unsupported operation was found
    485, ray1 inlined, size=81, file E:\Fortran\Fortran77\r.f77 (914)
         485, Accelerator restriction: induction variable live-out from loop: ..inline
              Accelerator restriction: multilevel induction variable: ..inline
    485, Accelerator restriction: unsupported operation: ACON
I don’t know what the “unsupported operation: ACON” means ,please kindly give me some advices.
Thanks a lot
Hi Teslalady,
Can you post or send an example of the loop?
A multi-level induction variable typically means an index variable is being calculated in the loop (such as in a while loop or “ia=ia+1”). ACON is a compiler term for a constant address. Though I’m not sure what’s causing ti here. I’ve seen this problem before we supported C pointer operation in compute regions, but that support went into the 12.6 release.
  • Mat
Hi,Mat, Thanks for your reply.
the code of No.485 line calls a subroutine, I think the error should be from this subroutine. so I post this subroutine as the attached code:
subroutine ray1(x0,z0,x_e,z_e,nz,nx,dx,dz,xu,zu,qq,
  •             vvxx1,vvzz1,xxx,yyy,ttt,ppp,pppz,xxx2,yyy2,ttt2
  •       ,ppp2,pppz2,idd)
real vvxx1(nz,nx),vvzz1(nz,nx)
real vvxx(nx,nz),vvzz(nx,nz)
real x_ray(90000),z_ray(90000)
real t(9000),pp(9000),ppx(9000),ppz(9000)
double precision x,z,dt,p,px,pz,v,p1,x1,x2,z1,z2,tx,tz
  •   ,tv1,tv2,vv1,vv2,dvx,dvx1,dvx2,dvz,dvz1,dvz2
do i=1,nx
do j=1,nz
vvxx(i,j)=vvxx1(j,i)
vvzz(i,j)=vvzz1(j,i)
end do
end do
num=1
ds=1
p=1000
px=psin(qq)
pz=p
cos(qq)
xxu=xu
zzu=zu
x_ray(num)=xu
z_ray(num)=zu
pp(num)=p
ppx(num)=px
ppz(num)=pz
do while((xxu.gt.x0.and.xxu.lt.x0+(nx-1)*dx).and.
  • (zzu.gt.z0.and.zzu.lt.z0+(nz-1)dz))
    num=num+1
    ix=(xxu/dx)+1
    iz=(zzu/dz)+1
    ks=ks+1
    vx1=vvxx(ix,iz)+(vvxx(ix+1,iz)-vvxx(ix,iz))/dx
    (xxu-(ix-1)dx)
    vx2=vvxx(ix,iz+1)+(vvxx(ix+1,iz+1)-vvxx(ix,iz+1))/dx
    **(xxu-(ix-1)dx)
    vx=vx1+(vx2-vx1)/dz
    (zzu-(iz-1)dz)
    vz1=vvzz(ix,iz)+(vvzz(ix+1,iz)-vvzz(ix,iz))/dx
    (xxu-(ix-1)dx)
    vz2=vvzz(ix,iz+1)+(vvzz(ix+1,iz+1)-vvzz(ix,iz+1))/dx
    **(xxu-(ix-1)dx)
    vz=vz1+(vz2-vz1)/dz
    (zzu-(iz-1)dz)
    dpx=-vx
    ds
    dpz=-vz
    ds
    px=px+dpx
    pz=pz+dpz
    if(pz.ne.0) qq=atan (px/pz)
    if(pz.eq.0) qq=3.1415926/2.
    if(qq.lt.0) qq=qq+3.1415926
    xxu=xxu+ds
    sin(qq)
    zzu=zzu+ds*cos(qq)
    x_ray(num)=xxu
    z_ray(num)=zzu
    pp(num)=p
    ppx(num)=px
    ppz(num)=pz
    t(num)=1
    end do
    xxx=x_ray(num)
    yyy=z_ray(num)
    ttt=t(num)
    ppp=pp(num)
    pppx=ppx(num)
    pppz=ppz(num)
    xxx2=x_ray(num-1)
    yyy2=z_ray(num-1)
    ttt2=t(num-1)
    ppp2=pp(num-1)
    pppx2=ppx(num-1)
    pppz2=ppz(num-1)
    return
    end
Hi Teslalady,
I don’t see any accelerator directives here so am assuming that you’ve put them around the while loop. Unfortunately, while loops can not be accelerated given that they are not countable (i.e. the number of iterations cannot be determined upon entry into the loop).
  • Mat
