I am trying to read a image in opencv which is taken by gphoto2 but have success in doing so. below is the error i get. MY image is taken from a DSLR via usb to Jetson nano.
images/2021-01-31
Failed to create the new directory.
File "tigger_dslr.py", line 74, in <module>
cv2.imshow("azx",q)
TypeError: Expected Ptr<cv::UMat> for argument 'mat'
My Algorithm is :
import time
#import sleep
from datetime import datetime
from sh import gphoto2 as gp
import signal , os,subprocess
import cv2
import numpy as np
from PIL import Image
from cStringIO import StringIO
import Jetson.GPIO as GPIO
channel = 7
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
GPIO.setup(channel, GPIO.IN)
#Kill the gphot porcess that starts when ever we connect the camera after a power cycle
def killgphoto2Process():
p = subprocess.Popen(['ps','-A'],stdout = subprocess.PIPE)
out , err = p.communicate()
#search for the line that has the process
#we want to kill
for line in out.splitlines():
if b'gvfsd-ghoto2' in line :
#kil the process
pid = int(line.split(None,1)[0])
os.kill(pid , signal .SIGKILL)
shot_date = datetime.now().strftime("%Y-%m-%d")
shot_time = datetime.now().strftime("%Y-%m-%d %H:%M:%S")
picID = ""
trigger_and_download= ["--stdout","--capture-image-and-download"]
folder_name = shot_date + picID
save_location = "images/" + folder_name
print(save_location)
def createSaveFolder():
try:
os.makedirs(save_location)
except:
print("Failed to create the new directory.")
os.chdir(save_location)
def captureImages():
return gp(trigger_and_download)
def renameFiles(ID):
for filename in os.listdir("."):
if len(filename) < 13 :
os.rename(filename , (shot_time +ID + ".JPG"))
createSaveFolder()
while True:
z = GPIO.input(channel)
if z == 0:
qwe= captureImages()
cv2.imshow("QWE",qwe)
their is a way around to first write the image on storage and then read it. but this is ugly engineering and is slow. i want to read it from the system ram
keeping in mind i already have gphoto2 istalled but canot make it python work
