I’m looking for GPIO physical address for pin A17 and A18, they are listed under USB2.0, I’m referring to page 37 of DATA SHEET NVIDIA Jetson TX1 System-on-Module (DS-07224-010_v1.0).
If I bypass A18 with a resistor then USB3.0 works. If I know the address then I can have a tiny driver to set it to active high. The better way would be to do this through device tree under xusb. I’m not sure how to do it.
Our carrier board uses PCIe-1 as USB2/3. I’ve this file and I tried to generate DTS file in the past but found that it produced the same DTS file with and without our required changes. We need the following
to configure DTS file and got both USB2.0 and USB3.0 with the register bypass for USB1_EN_OC# pin. We really don’t want to this hardware change rather we’d like to use this pin USB1_EN_OC#, it does not go high when we connect USB device, it does not produce wake up interrupt and the whole USB is off. Let me know what I can do more.
Hello, Hakim:
You can change the GPIO output value by either:
add code in kernel driver, request gpio pin, set output value of that GPIO pin.
edit the file u-boot/board/nvidia/{board}/pinmux-config-xxx.h, check xxx_gpio_inits.
please take a look at “arch/arm64/boot/dts/tegra210-platforms/tegra210-jetson-cv-pinmux-p2597-2180-a00.dtsi”
There’s the statement:
* When booting with U-Boot, U-Boot will program the entire
* pinmux itself, based on its own configuration tables. To
* avoid the kernel performing redundant pinmux configuration,
* U-Boot deletes the pinctrl-names property above. In that
* scenario, all of the pinmux data below is ignored. In any
* other scenario, the following pinmux data is still applied
* by the kernel.
