hi
I am writing assembler code on JETSON NANO that needs to use 40 PINS (for example pin 12)
I tried to search in the documents about GPIO base address and GPIO_SET_OFFSET
But I didn’t find it
Is there a document ?
Example code:
.section .data
gpio_base: .word 0x6000D000 // Replace with the actual base address
gpio_dir_offset: .word 0x00 // Offset for direction register
gpio_set_offset: .word 0x1C // Offset for set register
gpio_clr_offset: .word 0x28 // Offset for clear register
.section .text
.global_start
_start:
// Load base address of GPIO (0x6000D000)
ldr x0, =gpio_base // Load GPIO base address
ldr x1, [x0] // x1 = GPIO base address
// Configure GPIO pin 11 as output
ldr x2, =gpio_dir_offset // Load offset for direction register
add x2, x1, x2 // x2 = address of direction register
ldr x3, [x2] // Load current value of direction register
orr x3, x3, #(1 << 11) // Set bit 11 to configure GPIO pin 11 as output
str x3, [x2] // Store updated value back to direction register
// Set GPIO pin 11 high
ldr x2, =gpio_set_offset // Load offset for set register
add x2, x1, x2 // x2 = address of set register
mov x3, #(1 << 11) // Prepare value to set GPIO pin 11 high
str x3, [x2] // Store value to set register
// Infinite loop to avoid exiting
loops:
wfi // Wait for interrupt
b loop // Branch to loop
When I run the code I get the following error: “Segmentation fault”
From an investigation on the Internet, apparently I get the error because I am trying to access a memory component that I am not authorized to access (even when using SUDO)
I tried to look for the JETSON NANO base address in the documents but without success.
