I need my jetson to be able to run a script without having to go into the terminal and execute it. My plan is to put a button on the gpio pins to execute the script. My question is, how do I write a script that runs as soon as the jetson turns on, waiting for the gpio pin signal to be received and then runs my script?
As for gpio wiring, I am going to run a wire from pin 1, 3.3v DC, to pin 7, and have the script wait until it sees voltage at pin 7. I am using the python periphery GPIO library. Is this a correct way to do it, or am I going to fry my board? Any advice or help would be appreciated.
If I need to send a signal to pin 7 (1.8v), how to I shift the 5v output of the jetson to 1.8v? Or should I use the 3.3v output and then just use pin 7 with 3.3v?
