When I used Jetpack5.0.1/L4T 34.1.1 for our customized carrier board, the AGX’s gpiochip can work successfully.
After changed the BSP to L4T 35.1, the gpiochip wouldn’t work and got a error message " tegra186-gpio 2200000.gpio: Failed to set output direction: -517".
Seems it is caused from the changes of the “gpio-tegra186.c’” in L4T 35.1 version.
Because the L4T 34.1.1’s "gpio-tegra186.c’ file doesn’t call “pinctrl_gpio_direction_xxx” function in tegra186_gpio_direction_xxx function .
So I removed pinctrl_gpio_direction_xxx in it.
Then the gpiochip can successfully work.
Does NV has any ideal about this? Can you provide a correct way or any suggestion to fix this issue ?
static int tegra186_gpio_direction_input(struct gpio_chip *chip,
unsigned int offset)
//ret = pinctrl_gpio_direction_input(chip->base + offset);
//if (ret < 0)
//dev_err(chip->parent,
//“Failed to set input direction: %d\n”, ret);
return 0; //return ret;
static int tegra186_gpio_direction_output(struct gpio_chip *chip,
unsigned int offset, int level)
//ret = pinctrl_gpio_direction_output(chip->base + offset);
//if (ret < 0)
//"Failed to set output direction: %d\n", ret);
[ 6.697781] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 6.697789] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 6.698991] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 6.704410] serial-tegra 3110000.serial: Adding to iommu group 2
[ 6.705857] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 6.713578] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 36, base_baud = 0) is a TEGRA_UART
[ 6.718608] tegradc 15200000.display: dc_hdmi_hotplug_init: couldn’t get regulator vdd_hdmi_5v0, -517
[ 6.726614] serial-tegra 3140000.serial: Adding to iommu group 2
[ 6.732863] tegradc 15200000.display: dc_probe: failed hotplug init, -517
[ 6.822409] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 6.867359] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 6.884935] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2260000 KHz, changing to: 2265600 KHz
[ 6.886057] tegra194-cpufreq ccplex: probed with BWMGR
[ 6.887345] tegra186-gpio 2200000.gpio: Failed to set output direction: -517
[ 6.887426] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 6.887713] reg-fixed-voltage fixed-regulators:regulator@106: nonexclusive access to GPIO for fixed-regulators:regulator@106
[ 6.888264] tegra186-gpio 2200000.gpio: Failed to set output direction: -517
[ 6.888312] tegra186-gpio 2200000.gpio: Failed to set input direction: -517
[ 6.888581] tegra186-gpio 2200000.gpio: Failed to set output direction: -517
[ 6.891577] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 6.891634] sdhci-tegra 3400000.sdhci: BWMGR client registration for eMC Successful
[ 6.898440] tegra186-gpio 2200000.gpio: Failed to set output direction: -517
[ 6.898833] mmc0: CQHCI version 5.10
[ 6.911961] irq: IRQ267: trimming hierarchy from :interrupt-controller@3881000
[ 6.918155] tegra186-gpio 2200000.gpio: Failed to set output direction: -517
[ 6.921645] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 267
[ 6.927573] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 6.929275] vdd-5v-sata: supplied by vdd-ac-bat
[ 6.955182] tegra186-gpio 2200000.gpio: Failed to set output direction: -517
[ 6.962203] tegra186-gpio 2200000.gpio: Failed to set output direction: -517
[ 6.970874] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 6.971136] tegra186-gpio 2200000.gpio: Failed to set input direction: -517
