Gpio cc 03 why it from output low to output high,i do not need it output high,how can i change
gpio cc 03 why it from output low to output high,i do not need it output high,how can i change
Are you asking for AGX Orin platform?
Please have more specific question in details.
hello 2903932096,
would like to double check the platform you’re working with.
for example, is it AGX ORIN developer kit, or Orin NX developer kit, or, something else?
anyways, this GPIO pin, GPIO3_PCC.03, it’s used by Orin NX series as CAM_I2C_MUX.
you may disable this in sensor device tree if you don’t have camera use-case.
