GPIO Interrupt for Error Detection on NVIDIA Jetson AGX Orin (Jetpack 5.x & 6.x)
For those working on vision-critical applications using Jetson AGX Orin, I wanted to share a recent implementation we worked on: Camera Module Error Detection and Notification using GPIO interrupts.
This approach ensures real-time error handling by capturing signals from the camera sensor or microcontroller directly via GPIO — especially useful for safety-critical, multi-sensor vision systems in ADAS, robotics, and medical imaging.
Key Error Conditions Detected:
  • Frame Generation Failure (no frames from the sensor)
  • Over-Temperature Events (thermal threshold exceeded)
  • Hardware/Communication Faults (I2C/SERDES issues)
These errors can be reported through:
  • A dedicated GPIO interrupt line, or
  • Embedded metadata in the video stream
Implementation on Jetson (Jetpack 5.x & 6.x)
1. GPIO Interrupt Setup:
Set up the camera module or microcontroller to assert a GPIO when an error occurs. On the Jetson side:
  • Configure the GPIO in the device tree
  • Register an interrupt handler in the driver
Example Device Tree Snippet
&camera_sensor {
interrupt-gpios = <&gpio_controller GPIO_PIN GPIO_ACTIVE_HIGH>;
interrupt-parent = <&gpio_controller>;
2. Driver Integration:
Register the interrupt in your camera driver:
gpio_direction_input(error_gpio);
irq_number = gpio_to_irq(error_gpio);
request_irq(irq_number,
irq_handler,
IRQF_TRIGGER_FALLING,
“error_gpio_irq”,
NULL);
You can choose other trigger types too:
  • IRQF_TRIGGER_RISING
  • IRQF_TRIGGER_LOW
  • IRQF_TRIGGER_HIGH
3. Interrupt Service Routine (ISR):
Your handler might look like:
static irqreturn_t irq_handler(int irq, void *dev_id) {
// Log error, notify userspace, or take other actions
return IRQ_HANDLED;
This enables immediate reaction to hardware error events.
Jetpack 6.x Considerations (AGX Orin)
If you’re on Jetpack 6.x, PADCTL (pad control) registers must be configured explicitly to set the GPIO as an input.
Example: Configuring GPIO TEGRA234_MAIN_GPIO(AC, 7)
  • Find the Verilog ball name → SOC_GPIO60
  • PADCTL Register → PADCTL_G7_SOC_GPIO60_0
  • Address → 0x02448000 + 0x38 = 0x02448038
Certain GPIO pins on Jetson platforms are by default configured for SFIO (Special Function I/O) and will not function as general-purpose inputs until explicitly reconfigured.
Make sure to change the GPIO_SF_SEL: bit from SFIO to GPIO for proper working of the interrupt.
Summary
This implementation:
  • Provides reliable camera error handling
  • Minimizes reliance on software polling or frame monitoring
  • Ensures better real-time system health diagnostics
If you’re building a vision system on Jetson and need robust error handling from the hardware level, GPIO interrupt-based reporting is a clean and scalable solution.
This error-recovery feature is available in our 4K 140dB HDR GMSL2 camera based on OmniVision’s OX08B40 automotive sensor.
Happy to provide more detail or sample code on request.
Watch this video to know more about this 4K 140dB HDR GMSL2 camera
