GPIO Pin Selection Analysis for Frame Sync Signal Transmission
Hi Nvidia support team,
We plan to use Thor’s 4 GPIOs to send Frame sync signals to 4 deserializers respectively. Should we select GPIOs of type TSC?
However, I noticed that the public board design uses pin A48, which is not a TSC signal. Can we continue using pin A48 as per the reference design?
Additionally, does the frame sync signal need to be pulled high?
Thank you.
BR
GPIO38, 37, 17, and 42 with TSC_EDGE outputs should be used instead of I2C10_DAT pin A48, since the note says “not actual TSC”. The signals are push-pull at 3.3V I/O, so pull ups should not be used.
This Jetson Thor TSC-related post may be helpful: How to enable TSC function to generate camera trigger signals?
