Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
DRIVE OS 5.0.2
Target Operating System
Linux
QNX
other
Hardware Platform
DRIVE AGX Orin 32GB H01 Kit
Host Machine Version
native Ubuntu Linux 20.04 Host installed with SEEED Studio files
Hi, we are trying to figure out how to use GPIO pins on the AGX Orin but they donât seem to be configured.
We ran the command sudo /opt/nvidia/jetson-io/jetson-io.py to access a GUI that allows us to configure GPIO pins on the Jetson but got a fatal error message: âfailed to get pin number for nodeâ.
Afterwards we tried to run the same command again, but the GUI would open for 1 second before closing. Tried using sudo /opt/nvidia/jetson-io/config-by-pin.pybut got this error message:
Iâm trying to use GPIO pins to control a MD10C-R3 motor controller.
I ran a simple GPIO code:
import RPi.GPIO as GPIO
import time
output_pin = 18 # BCM pin 18, BOARD pin 12
def main():
# Pin Setup:
GPIO.setmode(GPIO.BCM) # BCM pin-numbering scheme from Raspberry Pi
# set pin as an output pin with optional initial state of HIGH
GPIO.setup(output_pin, GPIO.OUT, initial=GPIO.HIGH)
print(âStarting demo now! Press CTRL+C to exitâ)
curr_value = GPIO.HIGH
try:
while True:
time.sleep(1)
# Toggle the output every second
print(âOutputting {} to pin {}â.format(curr_value, output_pin))
GPIO.output(output_pin, curr_value)
curr_value ^= GPIO.HIGH
finally:
GPIO.cleanup()
if name == âmainâ:
main()
The output voltage at pins 12 and 18 remained at -3.271V, and was not changing from low to high and vice versa every second. The polarity also seems to be reversed because connecting a multi meter shows a negative output voltage.
In summary, we want to use GPIO pins for multiple actions such as steering and controlling an ODrive controller for driving but we canât seem to activate them through our code.
Hi, apparently the board was flipped and Pin 1 is on the opposite side of the labeling on the Jetson. The pins have a flipped configuration, which is opposite to the datasheet from SEEED studio.
We have fixed it after following the flipped configuration.
Thanks for your help, appreciate the quick replies.
