Gpio setting in devicetree on Jetpack 6.0 cause error
I am using Jetson Orin Nano Devkit, and Jetpack 6.0 L4T 36.3
I add gpio config in the devicetree overlay file as follow:
Then I use this overlay by editing the extlinux.conf
But when I reboot the device, it display “L4TLauncher: Unable to boot via extlinux: Device Error”
When I block this GPIO configuration, it works fine.
Could you please help to see what the problem is.
The problem is solved, the gpio configuration is written wrong, the correct is:
reset-gpios = <&gpio DES_PWDN GPIO_ACTIVE_HIGH>;
What is wrong is:
reset-gpios = <&tegra_main_gpio DES_PWDN GPIO_ACTIVE_HIGH>;
