I’m trying to modify a raspberry pi code to work on the jetson. The code works to write onto an Adafruit LED screen.
The existing code
import time
import Adafruit_GPIO.SPI as SPI
import Adafruit_SSD1306
from PIL import Image
from PIL import ImageDraw
from PIL import ImageFont
import subprocess
Raspberry Pi pin configuration:
RST = 24
Note the following are only used with SPI:
DC = 23
SPI_PORT = 0
SPI_DEVICE = 0
128x32 display with hardware I2C:
disp = Adafruit_SSD1306.SSD1306_128_32(rst=RST)
I’ve modified
import time
import subprocess
RST = 24
DC = 23
SPI_PORT = 0
SPI_DEVICE = 0
disp = Adafruit_SSD1306.SSD1306_128_32(rst=RST, i2c_bus=1, gpio=1) # setting gpio to 1 is hack to avoid platform detection
The issue lies in the GPIO library…I don’t think I really understand how the jetson’s works.
File “/home/jetson/EDITH/screen.py”, line 21, in
File “/usr/local/lib/python3.6/dist-packages/Adafruit_SSD1306/SSD1306.py”, line 288, in init
gpio, spi, i2c_bus, i2c_address, i2c)
File “/usr/local/lib/python3.6/dist-packages/Adafruit_SSD1306/SSD1306.py”, line 89, in init
self._gpio.setup(self._rst, GPIO.OUT)
AttributeError: ‘int’ object has no attribute ‘setup’
