GPIO warnings on (probably) customized carrier board
Hi guys, I know that Jetson xavier nx developer kit has SD slot and no EMMC; while Jetson xavier nx module has EMMC and no SD slot.
Recently I’ve purchased from a 3rd party Jetson xavier nx developer kit which has EMMC and no SD slot (it boots from the internal memory).
Now when I use Jetson.GPIO, I get the warning:
WARNING: Carrier board is not from a Jetson Development Kit.
WARNING: Jetson.GPIO library has not been verified with this carrier board
WARNING: and in fact is unlikely to work correctly.
The ids of the board is:
>> ls /proc/device-tree/chosen/plugin-manager/ids
3668-0001-300   name   XXXX-XXXX-XXX
The content of 3668-0001-300 is:
i2c@3160000:module@0x50
and of XXXX-XXXX-XXX is:
i2c@3160000:module@0x57
The content of the compatible of the device-tree reads as follows:
>> cat /proc/device-tree/compatible
nvidia,p3449-0000+p3668-0000nvidia,p3449-0000+p3668-0001nvidia,p3509-0000+p3668-0000nvidia,p3509-0000+p3668-0001nvidia,tegra194
I believe the ids of the board should have been:
3668-0000-300   name   3509-0000-100
The Jetpack version is the latest: v4.6
and Jetson.GPIO version is also the latest.
What do you recommend me to do? How to solve this warning?
Many thanks in advance.
hello Berr,
Jetson.GPIO library it only works with DevKits, this warning is expected since you’re having customize board.
