I want to be able to control the gpio34 signal which is connected to M.2 Alert on the carrier board. I don’t understand how I can control the signal however, because I don’t believe the signal name on the schematic is the same one I need to use in the terminal.
Also, if somebody understands how the M.2 Alert signal works and if it is necessary to the ssd function?
