Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
I developed a GPS custom plugin to work with DriveWorks/RoadRunner. It seems the plugin can read data just fine when using the sampe_gps_logger application.
However, When I added to RoadRunner/Rig file, It seems is not getting/parsing/decoding any data.
Found this post useful:
I want to know wehere I can find additional information about the packet that needs to be return from the Plugin when it is not CAN based.
All examples uses CAN bus and I am using a socket based driver implementation
Can you advise how to record data using the custom plugin? Should I use the sample_gps_logger for this purpose?
Currently, I am using sample_gps_logger with this command:
The GPS is not connected directly to the Target (Pegasus) but gets data over a socket connection. We are trying to use this GPS /INS unit instead of Xsense which is not working great for us.
