Currently I am looking for a easy to use GPS-Module with USB interface for the Xavier. ROS -support (ublox ideal) would be great. Has anyone some good recommendations? I appreciate much.
Best Regards
I don’t have answer for GPS module, but you may try on use it with Linux host PC to confirm the status.
May other developers help to share experiences.
I can confirm that the Navilock NL-602U runs smooth with the ros-melodic-nmea-navsat-driver
(nmea_navsat_driver - ROS Wiki)
(https://www.navilock.com/produkt/61840/pdf.html?sprache=en)
