Working on Jetson k1 board, with L4T software.
Could you please let me know, why all the partitions on the eMMC device is not listed out in u-boot cmd prompt and Linux command prompt?
Using the following gnu_linux_fastboot_emmc_full.cfg file, which is modified
Linux_for_Tegra/bootloader/ardbeg/cfg/gnu_linux_fastboot_emmc_full.cfg
[device]
type=sdmmc
instance=3
[partition]
name=BCT
id=2
type=boot_config_table
allocation_policy=sequential
filesystem_type=basic
size=2097152 #BCTSIZE
file_system_attribute=0
partition_attribute=0
allocation_attribute=8
percent_reserved=0
[partition]
name=PPT
id=3
type=data
size=8388608 #PPTSIZE
percent_reserved=0
#filename=ppt.img
[partition]
name=PT
id=4
type=partition_table
size=2097152
percent_reserved=0
[partition]
name=EBT
id=5
type=bootloader
size=4194304
percent_reserved=0
filename=fastboot.bin
[partition]
name=GP1
id=6
type=GP1
size=2097152
percent_reserved=0
[partition]
name=APP
id=7
type=data
size=1073741824
percent_reserved=0
filename=system.img
[partition]
name=EFI
id=8
type=data
size=67108864 #EFISIZE
percent_reserved=0
#filename=efi.img
[partition]
name=USP
id=9
type=data
size=4194304
percent_reserved=0
[partition]
name=GPT
id=10
type=GPT
size=0xFFFFFFFFFFFFFFFF
percent_reserved=0
#filename=spt.img
Listing the partitions on the MMC device in U-boot command prompt:
U-Boot
Tegra124 (Jetson TK1) # mmc part
Partition Map for MMC device 0 – Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00005000 0x01c04fff “APP”
attrs: 0x0001000000000001
type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
guid: 7369c667-ff51-ec4a-29cd-baabf2fbe346
2 0x01c05000 0x01c24fff “EFI”
attrs: 0x0002000000000001
guid: f854c27c-e81b-8de7-765a-2e63339fc99a
3 0x01c25000 0x01c26fff “USP”
attrs: 0x0003000000000001
guid: b70d3266-5831-5aa3-255d-051758e95ed4
test case 1:
root@tegra-ubuntu:/home/ubuntu#parted -l /dev/mmcblk0
Error: /dev/mmcblk0rpmb: unrecognised disk label
Warning: Not all of the space available to /dev/mmcblk0 appears to be used, you
can fix the GPT to use all of the space (an extra 1257439 blocks) or continue
with the current setting?
Fix/Ignore? I
Model: MMC SEM16G (sd/mmc)
Disk /dev/mmcblk0: 15.8GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Number Start End Size File system Name Flags
1 10.5MB 15.0GB 15.0GB ext4 APP hidden, msftdata
2 15.0GB 15.1GB 67.1MB EFI hidden, msftdata
3 15.1GB 15.1GB 4194kB USP hidden, msftdata
test case 2:
root@tegra-ubuntu:/home/ubuntu# fdisk /dev/mmcblk0
WARNING: GPT (GUID Partition Table) detected on ‘/dev/mmcblk0’! The util fdisk doesn’t support GPT. Use GNU Parted.
Command (m for help): p
Disk /dev/mmcblk0: 15.8 GB, 15758000128 bytes
256 heads, 63 sectors/track, 1908 cylinders, total 30777344 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 1 4294967295 2147483647+ ee GPT
Command (m for help): q
