Hardware: Jetson Orin NX 16GB
JetPack Version: r36.4.0 (L4T)
Base Image: nvcr.io/nvidia/l4t-jetpack:r36.4.0
Hi everyone,
I’m setting up a development environment on a Jetson Orin NX using VS Code Dev Containers and hitting a persistent permissions wall regarding GPU access for a non-root user.
The Problem:
I have a simple compiled CUDA test script. Inside the container:
- Running as a standard user (
./cuda_test): The script fails to initialize (likely permissions/driver access). - Running with sudo (
sudo ./cuda_test): The script runs perfectly and detects the Orin NX GPU.
The Setup & What I’ve Tried:
- Runtime Config: I have confirmed that
--runtime nvidiais active. Mydevcontainer.jsonincludes:
"runArgs": [
"--runtime=nvidia",
"--gpus=all"
- Device Node Permissions: I checked
/dev/nvidia*nodes. I have already usedchownto change ownership of these nodes to my container user, so they are not restricted to root on a file-system level. - Group Memberships: My container user has been added to the
root,video, andrendergroups:
Despite the device nodes being owned by the user and the user being in the correct groups, the CUDA driver seems to require root privileges to initialize the context.
I am using this with ROS2.
Thanks for any help/suggestion.
