I tried to install the GPU computing SDK 4.0.17.
Installshield is launched (with message “Starting InstallShield Wizard”), but shortly after that I get the message “Setup.exe stopped working” and setup is aborted. I tried both 32 & 64 bit SDK versions on 2 different PCs, both have Windows7 SP1 64bit installed. I redownloaded the SDK several times, with same result.
I successfully installed however the same downloaded exe on an old PC with Windows XP making sure that the downloaded file is not corrupted.
After a failed setup, I find the extracted installation files in my user folder …\AppData\Local\Temp..\Disk1. I tried to run setup.exe directly from there, but with the same error.
Has anyone a solution or explanation?
