GPU Crashes Sporadically with Deepstream
**• Hardware Platform (Jetson / GPU) GTX 1070
**• DeepStream Version 6.3
**• JetPack Version (valid for Jetson only)
**• TensorRT Version 8.5.3.1
**• NVIDIA GPU Driver Version (valid for GPU only) 530.30.02
**• Issue Type( questions, new requirements, bugs)**GPU Crashes Sporadically
Good day.
I have a rather complicated and large video processing application that I created with Deepstream 6.3. As the program became larger in scale, I saw that the GPU would sometimes crash sporadically. Sometimes I will be able to stream 20 videos simultaneously, but other times I only stream one video then the screen goes black and the GPU fan runs at 100% speed.
What can be the reason for this? And will I be able to adjust the configuration of the Deepstream program to ensure that this does not happen?
Can you share more log before the crash happens? You can enable coredump for more information about the crash.
Please monitor the GPU performance with “nvidia-smi dmon” when you running your case.
I’ve done some testing and saw that it is my GPU that is failing, I think that using deepstream for a prolonged period of might have overworked my GPU, Thank you for the suggestions!
