RTX3090• Hardware Platform (Jetson / GPU)**
6.1• DeepStream Version**
8.2• TensorRT Version***• NVIDIA GPU Driver Version (valid for GPU only)**
draw line with opencv in deepstream failed
n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
n_frame = draw_bounding_boxes(n_frame, obj_meta, obj_meta.confidence)
def draw_bounding_boxes(image, obj_meta, confidence):
confidence = ‘{0:.2f}’.format(confidence)
rect_params = obj_meta.rect_params
top = int(rect_params.top)
left = int(rect_params.left)
width = int(rect_params.width)
height = int(rect_params.height)
obj_name = pgie_classes_str[obj_meta.class_id]
# image = cv2.rectangle(image, (left, top), (left + width, top + height), (0, 0, 255, 0), 2, cv2.LINE_4)
color = (0, 0, 255, 0)
w_percents = int(width * 0.05) if width > 100 else int(width * 0.1)
h_percents = int(height * 0.05) if height > 100 else int(height * 0.1)
linetop_c1 = (left + w_percents, top)
linetop_c2 = (left + width - w_percents, top)
image = cv2.line(image, linetop_c1, linetop_c2, color, 6)
linebot_c1 = (left + w_percents, top + height)
linebot_c2 = (left + width - w_percents, top + height)
image = cv2.line(image, linebot_c1, linebot_c2, color, 6)
lineleft_c1 = (left, top + h_percents)
lineleft_c2 = (left, top + height - h_percents)
image = cv2.line(image, lineleft_c1, lineleft_c2, color, 6)
lineright_c1 = (left + width, top + h_percents)
lineright_c2 = (left + width, top + height - h_percents)
image = cv2.line(image, lineright_c1, lineright_c2, color, 6)
# Note that on some systems cv2.putText erroneously draws horizontal lines across the image
image = cv2.putText(image, obj_name + ‘,C=’ + str(confidence), (left - 10, top - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.5,
(0, 0, 255, 0), 2)
return image
