I can’t get this combination to work. The way I’m testing is with
ib_write_bw --use_cuda 0
It fails with
“Couldn’t allocate MR with error=14” (EFAULT)
when calling ibv_reg_mr to register the GPU memory
It seems L40S doesn’t support registering by DMA_BUF handle, and uses an earlier method that needs nvidia-peermem driver because cuDeviceGetAttribute(CU_DEVICE_ATTRIBUTE_DMA_BUF_SUPPORTED) returns false
But the nvidia-peermem kernel module is broken in Linux >= 6.8, because it removed support for ib_register_peer_memory_client that it uses uses and replaced it with registering by a DMA_BUF handle. According to NVIDIA GPUDirect over Infiniband Migration Paths - Kernel - Ubuntu Community Hub , if L40S doesn’t support DMA_BUF, then it sounds like, I either need to,
- downgrade Linux. Haven’t tried, but is undesirable.
- install proprietary Mellanox drivers + userspace (MLNX_OFED_LINUX). I tried it, but it got the same error
How can I get it to work? If that’s too hard, what is the correct code path for debugging? ibv_reg_mr → ? Mellanox extension …
Or should it be using ibv_reg_dmabuf_mr ? I don’t understand what the difference between registering by DMA_BUF handle and the previous method is. From reading nvidia-peermem.c, it seems the main thing it’s doing is translating virtual addresses to a list of physical pages for scatter, gather DMA (nvidia_p2p_get_pages). One would expect registering by DMA_BUF handle to be doing the same fundamental thing, so how can it not be supported? Or is it not a completely new hardware capability and more of an optimization like bindless textures?
