After latest updates I have a problem in Isaac ROS 4.0 installed on a Jetson AGX Thor Developer Kit:
admin@localhost:/workspaces/isaac_ros-dev$ nvidia-smi
NvRmMemInitNvmap failed: error Permission denied
NvRmMemMgrInit failed: Memory Manager Not supported, line 333
NvRmMemMgrInit failed: error type 196626
libnvrm_gpu.so: NvRmGpuLibOpen failed, error=196625
Tue Feb 3 07:06:55 2026
| NVIDIA-SMI 580.00 Driver Version: 580.00 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA Thor Off | 00000000:01:00.0 Off | N/A |
| N/A 36C N/A 3W / N/A | Not Supported | 86% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2520 G /usr/lib/xorg/Xorg 141MiB |
| 0 N/A N/A 2785 G /usr/bin/gnome-shell 58MiB |
It never happened to me before to have the nvidia-smi seemingly working but with errors: it either worked or not.
The Jetpack 7.1 is installed through SDK Manager.
Until a few days ago it all worked fine so I suppose it’s due to some package update.
It would seem a permissions problem, but since I didn’t change anything it’s not clear to me why this happens. If I’m not wrong, with isaac-ros-cli installed through apt I can’t pass params to the docker command: I also thought to try and build isaac-ros-cli from source and change the code there, but I’d like to understand if there’s some known fix before trying that.
I already tried to delete completely the docker images and re-install up to realsense dockerfile with isaac-ros activate --build-local, but the error remains the same.
The problem appears only on Thor, while on 2 different x86 machines it’s still working fine.
Thanks for posting in the Isaac ROS forum!
At this time, Isaac ROS is validated for JP 7.0.
Please refer to the documentation for installation instructions.
Based on the log you provided, your Docker container is running as non-root. The nvidia-smi command (and some libraries) attempt to open NvMap and fail with “Permission denied” inside the container, but they still successfully query the GPU via other paths.
If you need a clean log, you could try running nvidia-smi or other GPU tools from a root container.
Since it started showing that log, the Isaac Manipulation examples fail to load too since they don’t have access to the GPU.
I find it strange because I really didn’t change anything except running sudo apt upgrade outside the container.
I know that latest docker versions may have different params needed (see here for example), but it doesn’t seem the same problem.
First I’ll try tweaking the command that isaac-ros-cli uses to start the container.
If that doesn’t work I’ll try a fresh 7.1 install (it worked fine until last week).
Lastly I’ll try a fresh 7.0 install.
I don’t see other topics here with the same error, so it must be something in my local setup!
Could you please run the following inside the Isaac ROS dev container and share the full output? nvidia-smi || /usr/bin/nvgpu-smi ls /dev/nv* /dev/dri 2>/dev/null
For the records, I tried to fix the JP7.1 I had installed but with no success.
Once I reinstalled JP7.1 from SDKManager, the GPU permission problems in the isaac-ros containers were gone.
Then another problem did arise: as I was targeting Isaac ROS 4.1, probably in the last few days the repository metadata, signing keys or aliases weren’t completely updated and I had to modify the apt source list on Thor from:
deb [arch=amd64 signed-by=/usr/share/keyrings/nvidia-isaac-ros.gpg] https://isaac.download.nvidia.com/isaac-ros/release-4 noble main
To:
deb [arch=amd64 signed-by=/usr/share/keyrings/nvidia-isaac-ros.gpg] https://isaac.download.nvidia.com/isaac-ros/release-4 noble-jetpack main
My x86 machines obviously didn’t have that problem, and today I see it’s not necessary anymore.
I’ll keep going with the tests on Isaac Manipulation reference workflow!
I’ve rechecked the log you provided above, from JP 7.X, the old /dev/nvmap interface is no longer the primary way to allocate and manage GPU‑visible memory.
If you see messages like: NvRmMemInitNvmap failed: error Permission denied NvRmMemMgrInit failed: Memory Manager Not supported, line 333 NvRmMemMgrInit failed: error type 196626 libnvrm_gpu.so: NvRmGpuLibOpen failed, error=196625
it means the driver tried to initialize the legacy nvmap path, found it not supported/denied, and then falls back to the newer memory manager. As long as the GPU device nodes (e.g. /dev/nvidia*, /dev/dri/*) are present and nvidia-smi reports the Thor GPU correctly, these lines should be treated as warnings about the deprecated path rather than a complete GPU access failure.
I had to reflash and the problem is there again. It does load the nvidia-smi after the errors but any attempt to run something that needs the GPU fails:
Mon Feb 23 22:05:40 2026
| | | MIG M. |
| N/A 37C N/A 2W / N/A | Not Supported | 81% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2363 G /usr/lib/xorg/Xorg 189MiB |
| 0 N/A N/A 2564 G /usr/bin/gnome-shell 56MiB |
| 0 N/A N/A 2778 G /usr/bin/gnome-software 33MiB |
| 0 N/A N/A 11259 G /usr/lib/firefox/firefox 245MiB |
admin@localhost:/workspaces/isaac_ros-dev$ ros2 run isaac_ros_ess_models_install install_ess_models.sh --eula
**** EULA notice for asset: "dnn_stereo_disparity" ****
By continuing you accept the terms and conditions of the license as covered in the Model EULA, found here:
https://catalog.ngc.nvidia.com/orgs/nvidia/teams/isaac/models/dnn_stereo_disparity
Do you accept? [y/n]
y
Downloading artifact from https://api.ngc.nvidia.com/v2/models/nvidia/isaac/dnn_stereo_disparity/versions/4.1.0_onnx_trt10.13/files/dnn_stereo_disparity_v4.1.0_onnx_trt10.13.tar.gz to /workspaces/isaac_ros-dev/isaac_ros_assets/models/dnn_stereo_disparity/dnn_stereo_disparity_v4.1.0_onnx_trt10.13.tar.gz.
2026-02-23 22:06:22 URL:https://xfiles.ngc.nvidia.com/org/nvidia/team/isaac/modelsv2/dnn_stereo_disparity/blobs/sha256/be/bea73491e6732b332d27547329583c7a88926cd70189cf02c00afe498c1271ab/file?ssec-algo=AES256&versionId=BMhQQXZbDGc8TzjxVVirIXMNM0b4.JA.&ssec-key=AjgSYFQtjK8KHnPC%2FkWqMzy8hhtQzMr4qpRk1%2FU0g14RCFw%2FGwnuIK1KANPlJbODLZtCFgjkCDChVy%2BTxRt7UGCn2wK%2FBOx5mZx4LI0B%2Fg6Wur23RZgg071zuDJL56LmuDaIn0SxPjGmsKJyZhJL%2FrCQ7ldRLw5PGkUMa3MV40Jv6xNhaQc5B%2BKaOkMv5qGFarKQ7%2FYJDO5T8T8FlznauFELmWwu2AdAxvC55lKyQ7wskyk5lUDG37prwLJdQ%2BwiuRB3%2BixppCDvPQu3wPCPlzwJl4R%2BgiebLcInVTg%2F4SowcwjCmH0mtOZpEz8jRwx8sVgQnf3fJhAtdBm7opyXxqW3jFXQZOQA6EXtt32eXau1EkyAbRCa6XdPWB41qnCGnp9gp2B3dAwSqch0WUj7qtuSc2s7MR7rhB6y2Ffybmhl3Nm4xhot5lRdUR6yNSypmzaLIdlYCaEfe0GkmD8xg1TTZdiGDWV5WDLGLB0mRHL02DrBdIdebFL7D7aqDdj5&kid=bXJrLWU3OGM1M2FhZjE4YzRiNmJiNjlkYmRhZjcxNjA3YWEw&ssec-enabled=true&Expires=1771967158&Signature=oBEImn0op53fbLALHp0~Tf8xFCGaRYDyqASbMwZIqouv0ocMEMIAo~4eJr-vQkrbvurzA-ONaJDa1bSMybh6hVSu9Z~WUDMObenbgt9-WQaLHAY4na2VnQPw5372WaJBdRZD1oZhGfvyAedX3yy3qz3eyQJ0igqLvzcmMfjkvqS8uSO1rm9-kTKmnYNI6SDJ2xlW1G7DrkeC5Eo-vAjEFbGsSn3LNcLaZYfMVp1X1tIqglFZuViuA7i5OIEAj8R2y2ZmA-KPtcVksTMUp8~pR85pij67-i4v3cHFhix7XAbZDV-vJOUDgG3XerBqxoSdZfB7rlBUjWhilzPBe7yXQw__&Key-Pair-Id=KCX06E8E9L60W [131749133/131749133] -> "/workspaces/isaac_ros-dev/isaac_ros_assets/models/dnn_stereo_disparity/dnn_stereo_disparity_v4.1.0_onnx_trt10.13.tar.gz" [1]
dnn_stereo_disparity_v4.1.0_onnx_trt10.13/
dnn_stereo_disparity_v4.1.0_onnx_trt10.13/plugins/
dnn_stereo_disparity_v4.1.0_onnx_trt10.13/plugins/x86_64/
dnn_stereo_disparity_v4.1.0_onnx_trt10.13/plugins/x86_64/ess_plugins.so
dnn_stereo_disparity_v4.1.0_onnx_trt10.13/plugins/aarch64/
dnn_stereo_disparity_v4.1.0_onnx_trt10.13/plugins/aarch64/ess_plugins.so
dnn_stereo_disparity_v4.1.0_onnx_trt10.13/light_ess.onnx
dnn_stereo_disparity_v4.1.0_onnx_trt10.13/ess.onnx
Converting ESS onnx file to engine file.
&&&& RUNNING TensorRT.trtexec [TensorRT v101302] [b6] # /usr/src/tensorrt/bin/trtexec --onnx=/workspaces/isaac_ros-dev/isaac_ros_assets/models/dnn_stereo_disparity/dnn_stereo_disparity_v4.1.0_onnx_trt10.13/ess.onnx --saveEngine=/workspaces/isaac_ros-dev/isaac_ros_assets/models/dnn_stereo_disparity/dnn_stereo_disparity_v4.1.0_onnx_trt10.13/ess.engine --fp16 --staticPlugins=/workspaces/isaac_ros-dev/isaac_ros_assets/models/dnn_stereo_disparity/dnn_stereo_disparity_v4.1.0_onnx_trt10.13/plugins/aarch64/ess_plugins.so
Cuda failure at /_src/samples/common/common.h:1039: no CUDA-capable device is detected
[ros2run]: Process exited with failure 1
May I know how you flashed your device?
For now, the workaround is to use sudo su to switch to the root user when executing CUDA-related commands. We’re actively investigating the root cause and will let you know if we have any updates.
Also, I’m not sure if I need to follow all instructions to install docker on a freshly flashed Thor. Ok first boot Docker seems to be already close to the config requested for Isaac ROS CLI, but the instructions still request to install docker:
Also, I usually follow the Jetson Thor quickstart guide, except for the flashing procedure since I use SDK Manager. Here’s the only place where I find the instruction to set default-runtime:
I hope it’s still needed as I always execute that part.
Then later in the same Getting Started page that sent me to Jetson Quickstart, in initialize-isaac-ros-cli section, it tells me to install docker from official instructions.
Which instructions should I use to install docker? The Jetson quickstart, the official ones or both?
I flashed from USB and the access problem seems solved.
This time though I also followed official docker installation, thus removing previous docker install and re-installing it giving root access. I’m not really sure if this is the recommended procedure nor if it solved by flashing from a different route or by doing a different install process…
Thanks for pointing out the duplicated Docker steps in our docs, we’re working on streamlining that guide and updating it. The Docker issue you hit also appears to be a sporadic failure case, we’re continuing to investigate it and will keep you posted if there’s a relevant fix or new release.
