GPU fell off the bus, never recovered, now invisible even at lspci level after full cold reset
System:
  • MSI GE62 6RF (Apache Pro), 2016 model
  • GPU: Nvidia GTX 1060 (laptop/mobile), hybrid graphics with Intel iGPU
  • OS: Pop!_OS 24.04 LTS (fresh install, not an in-place upgrade)
  • Driver: 580.173.02 (via DKMS)
  • Kernel: 7.0.11-76070011-generic
Timeline / what happened:
  1. System was running normally. Suddenly the external monitor lost signal. The laptop itself stayed on and responsive , clearly still running, just the display session died.
  2. dmesg/journalctl around that time showed repeated:
   nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000927c:3:0:0x0000000f
  1. Rebooting did not resolve it — same error kept recurring.
  2. Did a fresh install of Pop!_OS 24.04 to rule out a software/config issue. Same problem persisted after a clean install.
  3. After the fresh install, nvidia-smi started failing outright:
   NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver.
  1. lsmod | grep nvidia → returns nothing (module not loaded).
  2. sudo modprobe nvidia fails:
   modprobe: ERROR: could not insert 'nvidia': No such device
  1. dkms status confirms the driver is properly built and installed for the current kernel (so this isn’t a “driver never installed” situation):
   nvidia/580.173.02, 7.0.11-76070011-generic, x86_64: installed
   system76/1.0.22~1785362089~24.04~90ea5e6, 7.0.11-76070011-generic, x86_64: installed
   system76_acpi/1.0.2~1784652717~24.04~add8f71, 7.0.11-76070011-generic, x86_64: installed
   system76-io/1.0.4~1732138800~24.04~fc71f15, 7.0.11-76070011-generic, x86_64: installed
  1. Performed a full cold reset: powered off, removed the battery, held the power button 30 seconds to drain residual charge, waited, reinserted battery, powered back on. Same result, GPU still not detected.
  2. lspci | grep -i nvidia returns nothing at all. Verified lspci itself works correctly, it returns full output for all other hardware, and lspci | grep -i vga correctly shows only the Intel iGPU, with no second VGA/3D controller entry for the GTX 1060.
  3. GPU stress test (VRAM + core) run earlier, before this worsened, reached 80°C with zero errors, no crash, no black screen, ruling out overheating as the original trigger
  4. nvidia-bug-report.sh output confirms the same picture from its own checkpoint: “Detected driver type: GPU Driver not installed? No NVIDIA driver modules detected”, consistent with a module that’s built but can’t load because there’s no GPU for it to bind to.
  5. Currently running stable on the Intel iGPU only; confirmed via glxinfo | grep "OpenGL renderer".
Summary of the contradiction I’m trying to resolve:
DKMS says the driver is correctly installed for my kernel. But the module can’t load (“no such device”), and the GPU doesn’t appear in lspci at all, meaning this isn’t a driver/config problem, it’s that the PCI bus itself isn’t reporting the device anymore, even after a full cold reset.
What I’m trying to figure out:
  • Is there anything else at the software/firmware level worth checking before concluding this is a dead GPU (solder/BGA failure), given it survived neither a normal reboot nor a full battery-pull cold reset?
  • Has anyone seen this exact 0x0000927c channel-state error progress from “recoverable with reboot” to “permanently undetected at the PCI level,” and found a non-hardware-repair fix?
nvidia-bug-report.log.gz (87.1 KB)
Given how suddenly it happened and the fact that cold reboots don’t help while no software changes were made, I’d bet for 99.9% that it was a hardware failure unfortunately :(
this has turned out to be more complicated than just “hardware failure or not.”
So forcing a rescan (echo 1 | sudo tee /sys/bus/pci/rescan) brings it back every single time it’s missing. After that, nvidia-smi and lspci both show it clean, no errors, normal power draw, everything looks fine.
But here’s the weird part: it’s not consistent across reboots. Sometimes I’ll just boot normally and the GPU’s right there, no rescan needed. Other times, same exact boot process, it’s just gone from lspci until I manually kick it with that rescan command. No ACPI errors or anything in dmesg either way when it’s missing, just NVRM: No NVIDIA GPU found, like it’s simply not announcing itself that time around.
Given that it comes back perfectly clean every time with a rescan, I’m leaning toward this being a flaky connection somewhere rather than the GPU itself being toast. But the “works fine on some boots, not others, no pattern I can find” part is what’s throwing me off.
This one’s less encouraging. After a few more reboots testing the rescan command, it stopped bringing the GPU back. lspci shows nothing no matter how many times I run echo 1 | sudo tee /sys/bus/pci/rescan.
Yep, looks like hardware failure after all.
