Hi all, vGPU newbie here. I have an HP DL380 thats running 13 high spec Visual Studio development VM’s, each one assigned to a developer who uses Remote Desktop to connect to. They are all saying that the UI is laggy, is there a GPU, or similar tech I can use in order for the VM’s to access better performing GPU for a snappier RDP UI?
Unfortunately there is not much you can do with Hyper-v as it doesn’t support vGPU. You would need a different Hypervisor first like ESX, KVM, Citrix or AHV.
Regards Simon
Thanks Simon, much appreciated.
